car wont start
car wont start
I was driving on the free way and my car just dies on me. I pulled over and tryed to start it again but it just cranks. Also while the engine is cranking the cam gears and timing belt are not moving. Did I jump a tooth or is my timing belt ****ed
Re: car wont start
is the timing belt still present ( wraped around the gears or?)
Re: car wont start
Sounds like the timing belt broke. You may not see that it's torn, but if you take the bottom timing belt cover off(the one behind the crank pulley) you should be able to see the belt is ripped completely in half.. Not a good thing. If you have an interference engine, you most likely bent some valves. Try taking the timing covers off and inspect the belt. Don't crank the engine over anymore.
Keep in mind the crank is what spins, so if it's ripped, the crank will spin, but the cam gears will not.
Re: car wont start
use service manual instruction to reset the belt properly and then try to start, hopefully the valves didnt smiley face your slugs.
Re: car wont start
for a second there, i thought seized cam for sure. but that would normally occur with the exhaust cam rather than intake, since it gets hotter.
it did get hot though. no doubt about that. i'm thinking it still may have seized. usually a lack of oil pressure is the cause. possibly an obstruction to the cam journal passages. and that definitely will cause the belt to skip.
since it is a b vtec motor, it's gonna be tight tolerances. highly likely bent valves
but i'm interested to know though, you said the starter was cranking, but cam gears and crank weren't moving. not seeing that as being possible, or extremely unlikely, as the crank is driven by the flywheel when the starter meshes. so if the starter is cranking, the crank must be moving...unless the crank has cracked. but i doubt that.
so what happened when you tried to turn it over? was the starter cranking? was the crank moving? were the cams moving? there are holes in your story that need filling
Re: car wont start
ive never seen a b-series with charred oil on the top-end like that,
maybe remove the cams and check the cam journals and caps for garring.
If you decide to do that I would still check for cam to camcap clearance with platigauge to still make sure your within spec.
And your right again, as with most tech threads, about holes in the story
GL OP let us know what comes of it.
Re: car wont start
I have seen this before. turned out the oil filter had collapsed and reduced the oil flow to the head. the cam siezed in the head and the key way for he timing gear on the crank sheared off.
If your cam did sieze you will need a new head and cam's.
Re: car wont start
^^now that makes sense. sheared keyway.
you can tear it apart and mic everything, but i'd be prepared to consider the motor to be unsalvageable.
could have also been a plugged pick up. guess he'll find out with the teardown
Re: car wont start
this is what I mean by voodo wierd ****!
If this is the case OP your MOMO is for the birds!
Re: car wont start
I think your right my brother was suppose to do a oil change while I was at work, turns out he changed the oil but not the filter now my crank is smooth no grooves for the crank pulley and belt if ****ed up
Re: car wont start
so I need a new head and crank? or can I just reuse my head and get new cams my cams are done for
Re: car wont start
you starved the engine of oil. it will need to be torn apart, cylinders checked, rings checked, cam and crank bores checked, crank, cam, and absolutely, all bearings checked. it's gonna be a full teardown if you want any guarantees.
pull that crank gear off. have a look at that key way
Re: car wont start
If the keyway is still present and crank and cams still spin, maybe the timing belt just simply failed???
Keep us posted as you tear down OP
Re: car wont start
Pull the cam caps and the cams off and take Pix i'll bet the heads Chewed to **** and the cams Are fried.
if this is the case you will just need a New head and cams but i would Take the time and rebiuld the lower end as well. might be cheaper to just get another Engine if your not up for a FULL rebuild.
Ether way i Want your Timing covers
Re: car wont start
Never mind the Pix was Very dark on my end but after i lightend it up i can see the melted aluminium around the cam on the #1 cam cap on the Exhaust cam.
Re: car wont start
since my head is done for what should I look for in the block to indicate damage besides scorched cylinder walls and piston play
Re: car wont start
scoring on the crank and rods
if your going for a NA rebuild or Near stock rebiuld.
i would get the block decked, crank polished, cyl honed, New rings, new rod and main bearings, NEW oil pump.
Also i still would like your Timing covers
I turned the crank to check if my timing belt was snapped. Do I have to return everything back to TD
jus2sho
15
10-09-2006 03:26 PM
90jdmcrxdude
05-17-2006 09:39 AM
hitvtecgetloud09
03-21-2004 05:27 PM
