Car won't start
Old 01-23-2011, 06:20 PM
ylor4's Avatar
Default Car won't start
1999 Acura Integra LS 5spd
I really need help. I thought I fixed the problem last week with a known working dizzy but then its happening again.
Here's the issue:
Sometimes the car won't start. When I try starting the car, I can hear the fuel prime, all power works, and the starter click. Other than that no cranks. No CEL. The car starts up on push start.
Here's what I've done, replaced the starter 3 times. The old ones worked fined on my cousin's integra. Replaced the dizzy. Replaced the alternator. Tested the battery. Checked all grounds.
Can anyone help? Thanks
Old 01-24-2011, 06:09 AM
fcm
Old Fart
fcm's Avatar
Default Re: Car won't start
If engine is not cranking, [starter motor not working] it has nothing to do with dizzy or alt., the problem is the starter circuit.
Start by doing a bypass jump, use a jumper to supply power directly to the starter motor solenoid control terminal, [smaller of the two leads on starter] unplug the lead, and jump power from the batt. or the batt. terminal on starter to the control terminal.
CAUTION, make sure car is not in gear and set the hand brake, engine WILL CRANK even if in gear and ign. is off.
If bypass jump works, you will need to check the starting circuit, [ign. switch, CIS, starter relay and wiring]. 94
Old 01-24-2011, 11:15 AM
UpNextCarParts's Avatar
uniquerider
08-12-2015 11:00 PM
Mike_C
02-26-2008 08:12 AM
mingchi69
07-14-2003 06:14 PM
elpermgrande
08-09-2002 06:43 AM
Quick Reply: Car won't start
