Car misfires at high-RPMs. - Honda-Tech
Old 01-06-2011, 08:04 PM   #1
Default Car misfires at high-RPMs.
My car was recently misfiring all of the time, regardless of how I was driving it.
(2001 Acura Integra LS Coupe/3dr/Hatchback/NOTEC)
So, I bought new spark plugs, wires, distributor cap and rotor.
My car was driving perfectly fine until about 2 weeks after buying the cap and rotor button and now it misfires until the engine is highly warmed up (about 20 consecutive minutes of driving at 60+MPH, then it will stop misfiring) and at high RPMs but only in 3rd+ gear.
For example, I can run it to 7k in first, 7k in 2nd and then about 5.5k in 3rd and the misfiring begins and it is HORRIBLE. I may make a video of it to better explain my situation, but it is multiple random misfires and so hard that it throws my aftermarket radio out of its holding place.
However, before driving on the highway/interstate (at the speed limit, so either 60MPH or 75MPH respectively) for a good 15-20 minutes, then it misfires just riding in 5th gear around 2.8-3.1K RPMs every 30 seconds or so.
I was told it could be my coil or coil wires going out.
What should I look into?
Gage™ is offline   Reply With Quote
Old 01-06-2011, 08:17 PM   #2
Default Re: Car misfires at high-RPMs.
well, this was happening to me not long ago. it was the dizzy. i just got a new dizzy. solved my problems. and my miss fire was HORRIBLE. at high rpms
vito352 is offline   Reply With Quote
Old 01-06-2011, 11:49 PM   #3
53JDMDC2's Avatar
id try a coil first. if that doesnt fix it. try a dizzy. you can always take the coil you baught out and keep it cause they always go out. and keep it. coils always go out.
53JDMDC2 is offline   Reply With Quote
Old 01-07-2011, 01:51 AM   #4
ha sounds familiar, this happen to me as well after 2 weeks from getting a new cap and rotor. It would misfire high rpms around 5500 and up. I open my cap and my rotor was loose the bolt came loose I tightened it took it for a test and it was all good now. you should check that out.
94db8R is offline   Reply With Quote
Old 01-07-2011, 12:44 PM   #5
Quote:
Hopefully this is my problem. Going to check it later and I'll take a look.
Intermittent misfiring on acceleration '95 Civic 5spd (Solved) MinimusMaximus Honda Civic / Del Sol (1992 - 2000) 12 12-07-2016 11:33 AM
96 Accord EX V Tech cylinder 2 misfire Btufts Honda Accord (1990 - 2002) 2 06-01-2016 07:51 AM
2000 Civic Ex P1399 2001CRV Honda Civic / Del Sol (1992 - 2000) 13 03-09-2016 02:23 PM
2001 LS (B18B1) STILL misfiring, please help. Gage™ Acura Integra 8 01-19-2011 04:28 PM
97 HX Misfire and Low Compression Alex Trebek Honda Civic / Del Sol (1992 - 2000) 3 10-12-2010 05:38 PM
Tags
2002, 3rd, acura, car, civic, gear, happening, high, higher, honda, mid, misfire, misfires, missfires, rpm, rpms, tls
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
