Will DC2 exhaust work on DB8?
Old 05-29-2012, 07:51 AM
R-gonaut's Avatar
Default Will DC2 exhaust work on DB8?
...with some minimal custom exhaust work? Mainly, will the B-pipe line up and slot in correctly?
Anyone done this before?
Thanks!
Old 05-29-2012, 03:03 PM
SuzukaBlueS2K's Avatar
Default Re: Will DC2 exhaust work on DB8?
I'm pretty sure that the mid pipe is too short to meet the rear section. You might be able to make a pipe section to go between...? I'm not sure though.
Old 05-29-2012, 03:05 PM
Hype-R Stalker
CleanLikeJdm's Avatar
The axle back is whats different, it's longer on the DB's.
Old 06-01-2012, 06:50 AM
R-gonaut's Avatar
anyone else?
Old 06-01-2012, 09:40 AM
variable's Avatar
This is correct. The axle back section of piping that attatches to the muffler is longer on the sedan. You would need to ask a muffler shop if they could make it work if your looking to go that route.
Old 06-01-2012, 09:46 AM
816d16 owes me money!
usdm420's Avatar
You can make almost any exhaust work on any car if you're willing to spend the dough to modify it to fit.
Old 06-01-2012, 01:55 PM
Dc2RaysCar's Avatar
i believe you can still use it, the only problem is that you won't be able to see your exhaust haha
Old 06-03-2012, 07:46 AM
EnjoyTheRideDC2's Avatar
The difference between the DC and DB exhaust is found at the muffler. The DB tail pipe section is 4 inches longer. All you need to do is extend the tip of the muffler, otherwise it will sit tucked behind the rear bumper.
Old 06-04-2012, 07:07 AM
R-gonaut's Avatar
Thanks dude, I've confirmed this separately and this is exactly what I'll have muffler shop do.
Thanks fellas!
YoungKadafi
12
12-06-2006 11:15 AM
riceburnerryan
11-22-2004 11:49 AM
mr2td
03-11-2002 07:01 PM
my_slow_civic
14
12-19-2001 09:15 PM
Quick Reply: Will DC2 exhaust work on DB8?
