Car just shuts off...cranks but no spark DA Integra - Honda-Tech
Old 12-23-2010, 12:34 PM   #1
Default Car just shuts off...cranks but no spark DA Integra
WASSUP HONDA-TECH..I HAVE AN ANNOYING PROBLEM THAT OVE BEEN TRYING TO SOLVE FOR THE LONGEST. ITS KINDA SAD THAT I GO TO LINCOLN TECH INSTITUTE AND NONE OF THE TEACHERS CAN FIGURE OUT THE PROBLEM..EITHER THERE FREAKING LAZY OR THERE JUS REALLY STUPID...
THE PROBLEM: SO MY CAR STARTS FINE IN THE MORNING AND THEN IF I DRIVE IT AROUND FOR LIKE SAY 10MIN 2O MIN. THE CAR JUST SHUTS OFF...NO BOGS NO STRUGGLE JUS SHUTS OFF....I GO TO TRY TO START IT BUT IT JUST CRANKS BUT DOESNT START. BUT IF I WAIT LIKE 5MIN AND THEN TRY STARTING IT AGAIN IT WILL CRANK AND START BUT THEN WILL SHUT OFF IN A WINDOW FROM 2MIN TO 15MIN..THEN THE SAME PROCESS I WILL HAVE TO DO OVER AND OVER...
THINGS I HAVE CHANGED THAT MIGHTVE BEEN THE PROBLEM
IGNITION COIL
IGNITOR
MAIN FUEL RELAY
FUEL FILTER
SPARK PLUGS N WIRES
CHECKED THE IGN TIMING AND BELT TIMING
THEN I CHANGED MY DISTRIBUTOR 3 TIMES TO MAKE SURE THEY WERENT DEFECTED.....
I MAKE SURE TO HEAR THE RELAY CLICK WHEN THE KEY IS TURNED TO ON AND THEN TURNED OVER WHICH I HEAR...I ALSO HEAR MY FUEL PUMP PRIMING SO I DONT THINK ITS THAT
THIS IS REALLY ANNOOYING A MECHANIC TOLD ME ITS PROBABLY MY ECU OR DISTRIBUTORAND I TOLD HIM I CHANGED THE DIZZY 3 TIMES. SO LEAVES ME WITH CHANGING MY ECU WHICH I HAVENT DONE YET..
ARE 1990'S INTEGRAS NONE FOR THIS PROBLEM?? PLEASE HELP NOT EVEN A JAPANESE MECHANIC CAN TELL ME WHATS WRONG WITH MY CAR
DO YOU THINK THAT MAYBE I CHANGED THE DISTRIBUTOR 3 TIMES THE IGNITOR KEEPS GETTING FRIED?
cream1316 is offline   Reply With Quote
Old 12-23-2010, 12:34 PM   #2
Default Re: CAR JUST SHUTS OFF...CRANKS BUT NO SPARK DA INTEGRA
PLZ HELP HT
Old 12-23-2010, 12:39 PM   #3
BUMPPPPPPPPPPP FOR HELP
Old 12-23-2010, 12:56 PM   #4
TTTTTTTTTTTTTTTTTTTT
Old 12-23-2010, 12:58 PM   #5
replace the dizzy, be happy
dc101 is offline   Reply With Quote
Old 12-23-2010, 01:00 PM   #6
TTTTTTTTTTTTTTTTTTTTTTT
Old 12-23-2010, 01:01 PM   #7
Quote:
I REPLACED IT 3TIMES ALREADY -_-
Old 12-23-2010, 01:53 PM   #8
b16-ef-si's Avatar
if u start the car and leave it on does it shut off? like turn it on and walk away...
or does it only shut off if u drive it?
idk what steps to diagnose u have done so just saying what i have done.
turn it on let it idle till the point where the fans kick in..
then do the wiggle test..might be a loose connection to the dizzy happened to me awhile back ago
b16-ef-si is offline   Reply With Quote
Old 12-23-2010, 03:43 PM   #9
H-T Order of Merit
Default Re: Car just shuts off...cranks but no spark DA Integra
Here's something you need to learn how to use:
nsxtasy is offline   Reply With Quote
Old 12-24-2010, 09:07 AM   #10
Quote:
HOW ABOUT MY KEYBOARD IS BROKEN IM PRETTY SURE WE CARE MORE ABOUT A VEHICLE THAN CAPITAL LETTERS
Old 12-24-2010, 09:08 AM   #11
DID THAT TEST ALREADY AND IT TURNS OFF WHILE IM DRIVING AND STILL TURNS OFF SOMETIMES AT IDLE
Old 12-24-2010, 01:18 PM   #12
I had the same problem it was a loose pins from the ecu
jdmson43 is offline   Reply With Quote
Old 12-24-2010, 01:51 PM   #13
Quote:
really that was the problem??? did u ever open up the ecu and see it specifically
Old 12-26-2010, 09:45 AM   #14
i found the problem ignitor inside the distributor
Old 12-26-2010, 10:28 AM   #15
wtf? i thought you changed it 3 times?
el crapitan is offline   Reply With Quote
Old 12-29-2010, 04:26 PM   #16
Quote:
yeaaa thats wat i said to myself but my ECU is giving me a code 15 which is the coil or ignitor... ive changed it 3 times from the same auto parts store they must be using bad cheap partss........im ordering a distributor for distributorking.com hopefully this clears the problem
Old 12-29-2010, 08:38 PM   #17
threw you up some advice on g2
Old 01-02-2011, 10:52 AM   #18
okk so i got a new distributor and my car isnt starting its just cranking and no cel is coming on-__-... wwhat a headache....i pulled out the spark plug and grounded it while cranking and theres no spark.... help ne1
Old 01-02-2011, 10:56 AM   #19
Quit buying junk auto zone distributors lol. Check evrything over again. Did you hook it up right? Check to make sure power going in. You need to find a known running car and borrow the dizzy and see if it runs yours.
94 ls-r is offline   Reply With Quote
Old 01-02-2011, 10:59 AM   #20
Quote:
the distributor is from parts authority if that makes it any better lol....both harnesses are connected right and so is the firing order..i do have fuel and air but no spark-__-.. i dont know anyone with a DA
Old 01-02-2011, 11:04 AM   #21
I see. My neighbor went thru 4 of the auto zone ones. He was gettin ready to tear into motor and I put my dizzy on and fired it up. Just because something is new doesnt mean it works. Can you test for power at the harness?
Old 01-02-2011, 11:13 AM   #22
yea thats tru something can always be defected but i dont have a dmm only a test light
Old 01-02-2011, 11:42 AM   #23
white_gsr's Avatar
dam dude your hell of problems but good luck hope you get everything squared away
white_gsr is offline   Reply With Quote
Old 01-02-2011, 11:46 AM   #24
test for power at the icm.
Old 01-02-2011, 11:59 AM   #25
vtecdc4's Avatar
Quote:
I THINK THE SOULUTION WOULD BE TO BUY A NEW KEYBOARD
vtecdc4 is offline   Reply With Quote
Engine Shut off and Start Issues 98' Civic deanazoom Honda Civic / Del Sol (1992 - 2000) 33 09-24-2015 01:44 AM
D15B7 shutting off SALOACCORDLX Honda Civic / Del Sol (1992 - 2000) 3 10-03-2012 05:14 PM
94 accord wont start... skeezy Honda Accord (1990 - 2002) 8 08-20-2010 12:47 PM
Same old problem... Car Wont Start after driving.. nObOdy65 Acura Integra 18 12-21-2005 03:04 PM
Car wont start immediately after shut down...did search curiousgpnoy Forced Induction 13 02-17-2005 04:24 PM
Tags
1993, 91, accord, car, cranks, cuts, da, honda, integra, loses, shut, shuts, spark, sparks, start, turns, whats, wrong
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
