Can overfilling your oil cause the engine light to come on?
Old 05-18-2004, 04:30 AM
integraboi1010's Avatar
Default Can overfilling your oil cause the engine light to come on?
I think I've overfilled my engine oil and just this morning I the check engine light came on.
What should I do now?
Old 05-18-2004, 04:41 AM
furious94ls's Avatar
Default Re: Can overfilling your oil cause the engine light to come on? (integraboi1010)
You think? Go pull the dipstick out. It should be inbetween the 2 dots. Full is at the second dot. If you are over then drain the oil out. Depending on what engine you have 4 or 4.2 quarts fills it. Pull the code for the CEL and see what it says.
Old 05-18-2004, 05:04 AM
Professor X's Avatar
Exactly! You don't want to drive around with too much oil. Drain it as soon as you can and make sure it has the proper amount. Good luck!
Old 05-18-2004, 05:13 AM
turbotegrar's Avatar
definately drain some out to the right amount, if you overfill you can blow seals and everything else, could be really damaging.
kmcgillic91
01-23-2011 07:47 AM
mraza
08-01-2006 11:24 PM
shraz
13
06-08-2006 08:11 PM
36Chambers
08-20-2002 05:33 AM
Quick Reply: Can overfilling your oil cause the engine light to come on?
