Can I remove the plastic behind the cam gears? - Honda-Tech
Old 06-07-2012, 02:47 PM   #1
Icon2 Can I remove the plastic behind the cam gears?
B18b1, bent the **** out of it, Can I remove it without problems? I think yes. Also, when installing the head gasket, which way do
The indents around the coolant and oil passages face, the block or head? The gasket has no markings.
Thanks
TravisBiggie is offline   Reply With Quote
Old 06-07-2012, 03:25 PM   #2
standy xsi's Avatar
Default Re: Can I remove the plastic behind the cam gears?
it's fairly only one way fit's. there is a part of the gasket that has number's on the bottem left hand side.
they should be faceing up. there is also a UP mark on the gasket that should be on the exhaust side.
and yeah you can remove the timing cover's but if something was to get stuck in there you could have big problem's
standy xsi is offline   Reply With Quote
Old 06-07-2012, 03:27 PM   #3
standy xsi's Avatar
the bit were i said there are number's, im gessn it's a multi layerd steel gasket.
they are on the secound part of steel on the gasket. if you have them make sure they are
on the left hand side faceing up
Cleaning products for engine block cleaning? StrayFromDaPath Honda Civic / Del Sol (1992 - 2000) 12 11-02-2016 07:07 AM
86 1.5L head gasket job ( o )( o ) Classic Hondas 7 08-22-2007 09:47 AM
b16a head gasket... OEM or SPOON? Master23 Honda Civic / Del Sol (1992 - 2000) 21 02-23-2006 04:33 AM
head gasket 1gEF-8 Honda CRX / EF Civic (1988 - 1991) 1 06-30-2005 07:19 AM
head gasket removal on an aluminum block. civicmatt Honda Civic / Del Sol (1992 - 2000) 6 02-21-2003 10:59 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
