CAN A BAD ALTERNATOR CAUSE WEAK SPARK AND SHORT OUT IGNITION COILS? - Honda-Tech
Old 03-16-2006, 04:51 PM   #1
B18ceed's Avatar
Default CAN A BAD ALTERNATOR CAUSE WEAK SPARK AND SHORT OUT IGNITION COILS?
I BUMPED MY BATTERY INTO THE FIREWALL AND EVER SINCE THE CAR HAS EXTREMELY WEAK SPARK AND WONT TURN OVER. IVE GONE THREW 2 IGNITION COILS AND ONLY ONE WORKED FOR ABOUT 20MINUTES AND THEN WENT OUT?PLZ HELP
B18ceed is offline   Reply With Quote
Old 03-16-2006, 09:18 PM   #2
yellowrexsi's Avatar
Default Re: CAN A BAD ALTERNATOR CAUSE WEAK SPARK AND SHORT OUT IGNITION COILS? (B18ceed)
Check the ignition fuse under the hood and make sure its not blown.
yellowrexsi is offline   Reply With Quote
Old 03-17-2006, 08:22 AM   #3
B18ceed's Avatar
Default Re: CAN A BAD ALTERNATOR CAUSE WEAK SPARK AND SHORT OUT IGNITION COILS? (yellowrexsi)
it looks good man, any other suggestions?
Old 03-17-2006, 08:39 AM   #4
DC2 Mang's Avatar
you probably have a bad connection, check all wires that run to the starter, alternatop and any ground wires running from the battery
DC2 Mang is offline   Reply With Quote
Old 03-18-2006, 05:41 PM   #5
B18ceed's Avatar
Default Re: CAN A BAD ALTERNATOR CAUSE WEAK SPARK AND SHORT OUT IGNITION COILS? (JDMdc2lsVtec)
does the ignition module control spark?
Icm (igniter) cause weak spark? b16a971 Tech / Misc 4 08-18-2016 02:16 AM
02 accord I changed ignition could now no start dmb2424 Honda Accord (1990 - 2002) 10 02-06-2015 03:43 PM
no spark after replacing cracked dizzy cap GPC91 Honda CRX / EF Civic (1988 - 1991) 10 01-21-2013 12:10 AM
97 civic ex - WEAK SPARK!! HELP marubcic Honda Civic / Del Sol (1992 - 2000) 5 07-26-2011 08:20 PM
Spark but no start Boostedb20EH2 Honda Civic / Del Sol (1992 - 2000) 27 05-29-2007 08:05 AM
Tags
altenator, alternater, alternator, altinator, bad, battery, ground, ignition, integra, make, short, shorting, spark, starter, weak
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
