Cam & Valvetrain install question
Im going to get my CTR's and valvetrain installed into my GSR next week. is there anything i need to know before i get this done?
i know i need to get a valve adjustment, but is there anything else?
and how much is a good price for the install?
im getting CTR cams, Spoon cam gears, ITR valvetrain, Portflow Retainers and Spoon Headgasket installed. TIA
anyone in Houston wanna get a group dyno going when i break these bad boys in?
Re: Cam & Valvetrain install question (da_rockwilda)
Oh, you're paying somebody to do the work? I'd offer to help if my schedule wasn't hellatious enough.
If I ever get a header for the GS-R, I'd like to dyno and see how much of a difference it made.
Re: Cam & Valvetrain install question (Jesse H)
thanks for the offer, but yeah, im going to end up paying someone.
i dont have a spring compressor nor the experience to use it. im also scared to mess with anything internally because i don't have the proper tools (torque wrench, valve adjustment tool etc.)
get all ur gaskets, seals, and grommets replaced with OE stuff
what type of header u using??
i would recommend ITr outer and portflow inner valvesprings
but ur set up sounds good
Re: Cam & Valvetrain install question (1fastGSR)
as of now, stock header, but ever since the "great header test" got back, im leaning towards a type-one, or a DC JDM. but that wont be for a while cause i have to drop my car....still stock height
Re: Cam & Valvetrain install question (MaliceGSR)
Looks easy and is easy are two different things.
If you don't have much experience working on an engine, pay someone to do it. I learned that the hard way (it's kind of embarassing to have to tow your car to the shop cause you screwed the pooch on an install).
