Cam seal oil leak, B18B Integra
Old 10-14-2009, 06:13 PM
senser1080's Avatar
Default Cam seal oil leak, B18B Integra
So I recently replaced my dinky plastic, and leaking cam seal cap, with an eBay metal one with two o-rings. I torqued things down properly and still I leak MORE oil than I did before.
It's leaking onto my transmission, block, in between the last two ports of my exhaust manifold, and, spraying onto my distributor.
Any ideas?
Old 10-14-2009, 08:25 PM
Global Moderator
Jimmy's Avatar
Default Re: Cam seal oil leak, B18B Integra
Any ideas?
I don't have any experience with the metal cam seals, but my good friend told me to stay away from them. So I did. I always just use oem honda parts/seals. I would try replacing it with OEM.
Also I would go ahead and pull of the dizzy and inspect the o-ring as well.
Old 10-14-2009, 08:36 PM
Spawne32's Avatar
the ebay one might not be machined properly, the blox cam seals are good, or the passwordjdm seals, make sure you lube the seal with oil as well before installing or you could damage the seal, i got lucky with mine cus i forgot to do that but its been fine.
Old 10-14-2009, 08:39 PM
icucnme's Avatar
Yeah I have a blox in my motor and it's holding up just fine. Like 20 bucks on ebay.
Old 10-14-2009, 08:48 PM
DAintegraGSR's Avatar
Did you use a lil HondaBond around those O rings... Iv just always done on my cars, dont know if its a must-do or not.
and is it definetly coming from the cam seal.I have seen in the past a piece of the valve cover gasket not seat properly right before you put it down on the head...maybe a possibility
Old 10-14-2009, 09:11 PM
TehGhett0P1mp's Avatar
Lube the O ring and hondabond around the seal, also check the dizzy o ring. Because I replaced the cam seal and it didnt fix my problem so I checked the dizzy and the seal was so streched out it fell out of position when I took the dizzy off.
Old 10-15-2009, 03:39 PM
senser1080's Avatar
Alright, thanks for the advice guys I'll be checking it out in a few minutes.
Old 10-15-2009, 04:01 PM
EG6Boy702's Avatar
I would replace the head gasket and get a normal cam seal with 2 o rings and it should be fine
Old 10-15-2009, 04:08 PM
westcoastjdm's Avatar
Hondabond and the seal is the main part!
You can have $30 cam seal, but if you do not seal it correctly, it is crap!
Golden Eagle is my favorite. Installed them for years, never had a problem
Old 10-15-2009, 04:12 PM
Global Moderator
Jimmy's Avatar
Originally Posted by EG6Boy702
I would replace the head gasket.
Elaborate on WHY you would do this.
Old 10-15-2009, 04:16 PM
Spawne32's Avatar
Old 10-15-2009, 04:36 PM
hybrid90's Avatar
^^ Maybe he meant the valve cover gasket?
Old 10-15-2009, 04:46 PM
follie gatts's Avatar
no. don't use hondabond on the seal's o-rings. lube the o-rings with motor oil. use honda bond between the aluminum--the cam holder that clamps the seal in place and the head.
Old 10-15-2009, 04:49 PM
DDTECH's Avatar
What the..
No..?
Old 10-15-2009, 04:54 PM
any of these metal caps come with instructions that say lube the o-rings with motor oil, not apply gasket sealer.
Old 10-15-2009, 04:56 PM
Spawne32's Avatar
Originally Posted by ALL M0T0R
What the..
No..?
what the..
yes?
hondabond is not a substitute for seals, if your replacing the cam seal with new orings you do not use hondabond along with it, it even states this in the manuals on where to use the honda bond
Old 10-15-2009, 05:04 PM
DDTECH's Avatar
Originally Posted by Spawne32
what the..
yes?
There's a reason, "honda" makes hondabond..
Its ment for these little leaks like this..
When i assemble engines, i use it where i see necessary..
I used hondabond over the dizzy oring, the cam seal o rings. Around the water pump gasket and oil pump gasket. Its amazing, i've yet to have any motors leak. I do this with my own as well, infact, the one i just built 3 weeks thats in my car, doesn't leak from anywhere..
Hondabond is made for those annoying spots.. Alot of people use hondabond on the corners of the valvecover gasket around the hills and corners so that **** doesn't leak..
Using motor oil doesn't STOP leaking..alum expands as it gets hotter.. using hondabond , allows it to make a complete seal all the way around, when hondabond gets hot, it expands a tiny bit and gets hard, providing the seal anything needs.. I used this around the O rings on the waterlog as well.. and we all know how loose that thing is..
Use hondabond.. dont use motor oil.. thats just plain dumb.
Old 10-15-2009, 05:06 PM
DDTECH's Avatar
It's 4 dollars a tube at a local honda dealership, and probably worth every penny, i use that stuff on **** around the house.. its a good sealent and works in all temps.
Old 10-15-2009, 05:07 PM
DDTECH's Avatar
Quote for humor from honda
"HONDABOND is a high-temperature silicone liquid gasket. It's unique formula is non-acidic and won't corrode aluminium like other silicone gasket products will. Best for use in areas not requiring solid gaskets"
cam seal a solid gasket?? No, its not..
Old 10-15-2009, 05:13 PM
Spawne32's Avatar
and this is why i cant stand pulling engines apart after people like yourself get a hold of them, and i spend hours picking silicone gasket out of places it shouldnt be. The motor oil doesnt stop leaking, it allows the o ring to seat easier without damaging the oring, its designed to be a perfectly tight seal, and if you force it in without lubrication you can damage the seal on install, you dont damage the seal and then get a tube of honda bond and half *** it like your suggesting.
Old 10-15-2009, 06:28 PM
EG6Boy702's Avatar
i didnt read anything else but if it were leaking oil onto the transmission and he replaced the cam seal already and its still leaking MAYBE its the head gasket
Old 10-15-2009, 08:30 PM
senser1080's Avatar
Okay well back on track, the cam seal looked fine, and I remember when I did install it I lubed it up, but not as much as I lubed it up now. I'm going tomorrow to the Honda dealership to buy a new VC gasket, not a head gasket, and some hondabong.
I ended up screwing myself over because I overtorqued one of the valve cover studs and snapped off the nut cap and bolt. >
So tomorrow's shopping list. New bolt, new nut cap and washer, hondabond, and a VC gasket.
Old 10-15-2009, 08:35 PM
TegRr's Avatar
LOL! I totally agree with this guy.
Do you see Honda putting hondabond on any seals on the motor? Nooooo. If your using good parts and the surface is good you shouldn't have to use hondabond on brand new seals. Then it's just a bandage. Just a little oil so they don't tear during the install. Yes, you see hondabonds on surfaces that has two mating parts like on the valve cover.
Old 10-15-2009, 09:14 PM
Spawne32's Avatar
can you pinpoint a location as to where its coming from? if its leaking from the cam cap seal then you will know it, cus it will look like this...
Old 10-16-2009, 06:51 AM
DDTECH's Avatar
damn, is that a factor seal?
whats that white **** around it..
"hondabond"
put hondabond on it and get this over with, these kids dont know what they are talking about..Hondabond has a purpose and this is one of them.
Quick Reply: Cam seal oil leak, B18B Integra
