bumper crack. help fix! plz
can yall tell me some step to fix my front bumper crack myself...
and its not a too bad crack.. i just need somethi like glue or ..
make the crack closed. so i dont have to worry when i try to repaint it...
Re: bumper crack. help fix! plz (qqyycchh)
theres a 'plastic welder' its kinda like a soldering iron, but you can put filler rod in it, probably can find it at menards. or you can fiberglass it.
Re: bumper crack. help fix! plz (95teg_ls)
I used that plastic weld stuff on my bumper.I was not satisfied at all with the results.This is why im biteing the bullet and getting a new bumper.If your crack is small enough you should be able to fix it and make it look pretty good.Best of luck to you.
Daisy... Daisy...
Drill the end of the crack to stop the propagation. Then clean the area with paint thinner. Remove the paint from the immediate crack area. Use a solderiing iron to melt and fuse the plastic in the crack. Do this from both sides. Make sure that the seam in the front is recessed. Use polyester body filler for the body work.
92HB_HB
10-21-2004 08:13 PM
Xymox007
07-22-2004 03:01 PM
DSeriesBeeKilla
12
07-14-2003 06:28 AM
