Water Leak inside FRONT of car...
Old 07-24-2008, 08:42 AM
mandymoo2182's Avatar
Default Water Leak inside FRONT of car...
I have a 97 GS... It seems to only happen when I use the A/C... but water will spray out from behind my glove box all over the floor and will even spray out the driver side behind the center console. The really wierd part, is that the water that sprays out into the driver side is always freezing cold, but 50% of the time the water coming out onto the psgr side is either ice cold, OR burning hot - and I mean SUPER hot. Any suggestions? We can't seem to figure out how the heck this is happening.
Old 07-24-2008, 09:14 AM
JEGD16Z6's Avatar
Default Re: Water Leak inside FRONT of car... (mandymoo2182)
check ur ac drain tube its may be clogged. im not to sure on where it is but i know it comes out somewhere under the car pass side look for a rubber tube
Old 07-25-2008, 08:22 AM
jwrape's Avatar
I have theexact same issue. Leaking in the front passenger side floor board.
Don't know where to look for the A/C condensation overflow though
Old 07-25-2008, 01:07 PM
Neptronix's Avatar
Default Re: Water Leak inside FRONT of car... (jwrape)
it's definetely your AC. This is not easy to diagnose on your own without the proper tools to fill and purge the AC system.. i would take this to a shop, really.
Old 07-25-2008, 05:25 PM
myteggy95's Avatar
MY 95 HAD THE SAME PROBLEM THERE IS RUBBER TUBE THAT RUNS FROM THE FIREWALL TO THE BACK OF THE AC UNIT BEHINED THE GLOVE BOX JUST FEEL AROUND IF IT PULLED OUT IT SHOULD BE EASY TO PUT BACK IN
thekid2390
06-30-2013 12:15 PM
DACteg
07-27-2010 11:04 AM
No-Gi
10-03-2009 06:30 AM
turbogenetic
04-16-2009 10:12 AM
gtowni3
10-05-2004 06:19 PM
Quick Reply: Water Leak inside FRONT of car...
