Bubbles in motor oil (Dipstick) - Honda-Tech
Old 12-28-2008, 09:37 AM   #1
5.56's Avatar
Default Bubbles in motor oil (Dipstick)
Is this somthing I should be concerned about. I checked the oil in my car after its been driven and I see very small bubbles in my oil on the dipstick. Almost microscopic. And its not the foamy, milky substance associated with water in the oil or a blown headgasket. Anyone have a clue what is causing this?
5.56 is offline   Reply With Quote
Old 12-28-2008, 09:51 AM   #2
1SicLS's Avatar
Default Re: Bubbles in motor oil (Dipstick)
normal
1SicLS is offline   Reply With Quote
Old 12-28-2008, 10:03 AM   #3
5.56's Avatar
Thanks!
Old 12-28-2008, 12:14 PM   #4
might be ur oil pump going bad!!!! but i might be wrong
MasterLsGod is offline   Reply With Quote
Old 12-28-2008, 04:48 PM   #5
5.56's Avatar
Quote:
Is there any other way to tell if your oil pump is messing up? If thats one sign.
Old 12-28-2008, 06:00 PM   #6
Double Agent's Avatar
Lots of bubbles can mean you have overfilled your oil. Make sure your level is correct. It's rare for the oil pump to fail and if it did it probably wouldn't work at all and your oil light would come on. Small bubbles are normal, so I wouldn't worry too much.
Double Agent is offline   Reply With Quote
LSv Turbo - No oil on dipstick diviznrider Forced Induction 15 01-31-2012 10:07 PM
Air bubbles on oil dipstick??? blu3g Honda Civic / Del Sol (1992 - 2000) 7 11-21-2008 06:27 AM
blown head gasket? ericstambaugh07 Honda Prelude 13 06-25-2007 10:08 AM
Oil Dipstick AGB5901 Honda Civic / Del Sol (1992 - 2000) 9 04-24-2003 01:56 PM
Air bubbles in Oil Web_Head Acura Integra 6 11-04-2001 01:41 AM
Tags
2006, bad, bubbles, car, civic, dip, dipstick, engine, full, honda, mark, milky, motor, oil, stick
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
