Brown milky substance under oil cap - Honda-Tech
Old 02-12-2007, 10:25 AM   #1
97CWITR's Avatar
Default Brown milky substance under oil cap
Went to top up my oil and found milky light brown coloured stuff under my oil cap.
I'm sure it's a result of my engine overheating a week before.
What does it mean? Coolant in the oil? blown headgasket?
Anything else i should check for?
Thanks
97CWITR is offline   Reply With Quote
Old 02-12-2007, 10:28 AM   #2
yc_dc4mar's Avatar
Default Re: Brown milky substance under oil cap (96BLkGSR)
yes your are right. blown head gasket. you got coolant in your oil.
you better get that fixed asap
when you replace your head gasket make sure you also replace your thermostat. thats most likely gone too.
and im not sure if theres anything else. if you want, when you pull off your head check it out and make sure its ok. when i over heated my engine, a chuck was missing from one of my valves.
goodluck
yc_dc4mar is offline   Reply With Quote
Old 02-12-2007, 10:42 AM   #3
nate_2k5's Avatar
Default Re: Brown milky substance under oil cap (yc_dc4mar)
x2 .... or i guess
nate_2k5 is offline   Reply With Quote
Old 02-12-2007, 04:02 PM   #4
97CWITR's Avatar
Would i not have the same stuff in my oil pan then?
Talked to a reputable engine builder today he explained that during really cold weather and heat cycles condensation mixes with oil to make that...
anything else i should look for before taking the head off?
Old 02-12-2007, 04:06 PM   #5
nate_2k5's Avatar
you could suck up some coolant and check the color of it
Old 02-12-2007, 04:18 PM   #6
Shank6510's Avatar
Water in the oil possibly... Seriously I asked this exact question to my autos teacher this morning.
Shank6510 is offline   Reply With Quote
Old 02-12-2007, 05:14 PM   #7
Semper Fidelis
SlammedDC2's Avatar
Default Re: Brown milky substance under oil cap (Shank6510)
Cant you do a leakdown to check for this as well?
SlammedDC2 is offline   Reply With Quote
milky oil in the head what can cause this JdmJah Honda Civic / Del Sol (1992 - 2000) 16 02-19-2013 07:42 PM
oil dripping from distributor cap.. xcoregage Tech / Misc 1 12-18-2009 01:07 AM
Milky oil from turbo return nihad Forced Induction 8 10-01-2008 04:22 PM
white milky substance under oil cap? 01accordlx Honda Accord (1990 - 2002) 18 12-27-2007 05:47 PM
white milky residue under oil cap. kidcool1977 Honda Accord (1990 - 2002) 12 12-10-2007 09:45 AM
Tags
brown, brownish, cap, civic, color, coolant, dil, engine, integra, light, milky, oil, stuff, substance, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
