broken clutch springs - Honda-Tech
Old 06-22-2012, 08:08 PM   #1
soon2bdropped's Avatar
Default broken clutch springs
hello there i have an 97 ls 5spd.. very hard to go into gear. would go innto gear with car off. remove transmission inspected clutch found one of the clutch spring damaged/broken. theres 4 and one is broken. i dont understand,the spring is there for smooth engagement. how does it affect not being able to shift into other gears.. someone help me i dont understand.
soon2bdropped is offline   Reply With Quote
Old 06-22-2012, 08:27 PM   #2
EK9
Dc4LsTeG's Avatar
Default Re: broken clutch springs
What don't you understand? Change your clutch
Dc4LsTeG is offline   Reply With Quote
Old 06-22-2012, 08:28 PM   #3
i did. i want to know the mechanical part of how it causes it
Old 06-22-2012, 08:31 PM   #4
EK9
Dc4LsTeG's Avatar
I believe its usually from just getting old
Old 06-23-2012, 12:43 AM   #5
Quote:
When the spring is broken, or wears through its retaining lips, it can get jammed between the flywheel and the friction disc. This prevents the friction disc from losing contact with the flywheel and the pressure plate; the effect is exactly as though you didn't push the pedal down when changing gears.
TheRealTegger is offline   Reply With Quote
Old 06-23-2012, 12:57 AM   #6
Quote:
When it comes to Genuine Honda clutch parts, broken springs or ones that have worn through their retaining lips are a result of poor clutch technique.
Poor clutch technique involves bumpy, jerky, or harsh engagement. Each bump or jerk compresses the springs more than a smooth engagement would. Each excessive compression weakens the springs a little, and wears away the retaining lips a little. Eventually, a spring will either break or escape from its little jail.
Aftermarket clutches may not be as well-made as OE, so broken or escaped springs may be due to poor materials or construction, instead.
An OE clutch, properly used, will last over 250,000 miles. I know, I've done it. My original clutch was replaced at 255,800 miles. I now have 131,200 on the replacement.
See here for details: http://www.tegger.com/hondafaq/clutch/index.html
Old 06-23-2012, 04:46 PM   #7
so basicially as your pressing the clutch.. the disc move away from the flywheel but the spring pops out and slightly touches the flywheel which will spin the clutch the same speed as the engine and not cause it to go into gear is this correct?
Old 06-24-2012, 05:12 AM   #8
That's correct. The jumped spring may not necessarily cause the clutch disc to turn at the exact-same speed as the engine, but the effect will be the same.
What can also happen is the spring may come out of its recess momentarily, then fall back in again. This can cause the confusing situation where shifting problems are intermittent, with shifting being normal at other times.
Old 09-06-2012, 03:06 PM   #9
i know this is an old thread but i just ran into the same problem
i am seriously pressed on time to get my prelude running and am considering putting in the old disc with the missing spring, is it possible?
all i can think of is it being unbalanced or having a huge weak spot where the spring used to be
oneday is offline   Reply With Quote
Clutch/Transmission Problems??? Moaltar Honda CRX / EF Civic (1988 - 1991) 4 10-21-2013 12:25 PM
WTB: broken/grinding Honda/Acura B-series transmissions (near Atlanta) phatcardesignz Southeast (Sales) 0 01-06-2012 12:48 AM
Flywheel resurfaced? Terry36 Honda Civic / Del Sol (1992 - 2000) 3 12-07-2011 05:48 AM
For those who have broken oil pump gears Jared Drag Racing 65 01-09-2007 07:45 PM
92-00 ex/si tranny ( HOUSINGS ) LSD_EG Honda Civic / Del Sol (1992 - 2000) 4 02-02-2006 11:35 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
