Brake lights & horn do not work!!!
Old 02-20-2014, 12:36 PM
sporter804's Avatar
Default Brake lights & horn do not work!!!
Hi, new to the site but not new to coming for advice here. Always found a good explanation of what I needed to get done. However this particular problem is a little different from some of the others I've read about.
To get started I have a 1997 Acura Integra GSR 1.8L DOHC. My horn and brake lights both went out not to long ago and was stopped by a cop (for the obvious safety reasons). I replaced the 20A fuse, which was blown, with a new one.
Started the car, checked the brake lights and they worked! Sweet. Then pressed the horn to check.... Nothing . Hmmm. Check the brakes again. No good .
So I'm assuming it's an electrical issue within my steering wheel. Not exactly my forte when it comes to mechanics but have a high aptitude and a brother that knows electrical work. What direction should I go in?? Thanks for any response.
Old 02-20-2014, 05:20 PM
fcm
Old Fart
fcm's Avatar
Default Re: Brake lights & horn do not work!!!
Unlikely a problem in the steering column, horn button only supplies a ground to the horn relay.
Because the fuse blows when you press the horn button the problem will be after the horn relay, possibly the horn itself is shorted out, unplug it and try a new fuse, if fuse does not blow, [brake lights keep working after pushing horn button] replace the horn.
If fuse still blows, find short in horn lead between horn relay and horn. 94
Fritz_eh
Honda Fit
10-17-2021 07:11 PM
ek4_b16a
07-02-2009 10:20 AM
sleepercivic69
11-11-2006 11:18 AM
cmyrex
07-12-2006 04:27 PM
_RedRiceR_
12-21-2004 05:23 PM
Quick Reply: Brake lights & horn do not work!!!
