Brake Clicking Sound - When Applied And Released - Honda-Tech
Old 09-25-2008, 12:12 AM   #1
Mfoehrkolb's Avatar
Default Brake Clicking Sound - When Applied And Released
This is bothering me so badly. I don't know what to look for really.
If i am driving at 40mph. I apply the brake moderately to slow to 20mph. There is a click when engaged and a click when disengaged. I can feel it in the pedal and hear it. It sounds like it is coming from my front right spindle.
I have brand new axles in the car with 100 miles on them, and new brakes, and tie rods all around. It has to be something with my braking system because it only does it when applying and letting the brake on and off.
Anyone else experience this? I don't want to drive and have something worse happen to me or my loved ones while in the car.
Mfoehrkolb is offline   Reply With Quote
Old 09-25-2008, 12:18 AM   #2
Mfoehrkolb's Avatar
I did some research and these are a couple choices that i have read.
Brake pads are moving around a bit in the holder?
Some type of bolt holding the piston into place?
The entire caliper itself moving?
Inner/Outer Tie rod, ball joints etc etc. being lose or becoming lose. (Moves when weight is applied and taken off)
I recently replaced all my wheel studs in the front about 1 week ago because they were becoming worn /stripped. I am sure i tightened everything to the best of my ability. I only have been driving the car for about 1.2 weeks and didn't take notice to it before i did the wheel studs. Pretty sure it still was making the noise though.
Old 09-25-2008, 12:30 AM   #3
garados's Avatar
Default Re: (Mfoehrkolb)
definitely take a look at the brake pads as well as the caliper-to-hub mounting bolts, just to make sure that nothing is moving. Another thing would be to check the brake fluid. I had some funky clunking sounds and feelings in my old gsr's clutch pedal when there was gunky fluid in the master cylinder.
garados is online now   Reply With Quote
Old 09-25-2008, 12:46 AM   #4
Mfoehrkolb's Avatar
Default Re: (garados)
Quote:
--- I bleed them when i got the car on the street. There was no fluids in the car at all. So everything should be fresh, but i could re-bleed them to see if any gunk will come out now since it has been in use.
This is def. something i don't want to mess around with because of being able to stop is pretty serious. If i recall correctly.
Old 09-25-2008, 01:32 AM   #5
garados's Avatar
Yeah, being able to stop is a nice feature on any car Check the bolts and also the caliper sliding pins to see if they're clean and have good grease on them. They should slide very easily into the caliper mounting bracket.
Old 09-25-2008, 07:45 AM   #6
AWD Terror's Avatar
I had the same issue once.
When I got new pads, they didn't come with the little metal piece that holds them in place. I said screw it and it did the same thing you are talking about until I got a new set.
The clicking noise was loud as hell.
AWD Terror is offline   Reply With Quote
Loud clicking noise when breaking Hypnotise305 Suspension & Brakes 6 09-15-2013 05:49 PM
Brake Rotor Grinding TrakDay Acura Integra 7 10-25-2006 07:29 PM
Problem with a clunking noise coming the driver side when applying brakes at low speeds I don't know ramz7887 Tech / Misc 2 12-06-2004 04:16 AM
New brakes and now it shakes! didyouhearthat Honda CRX / EF Civic (1988 - 1991) 10 08-09-2004 11:39 PM
Brake problem or bad tie rod? Turbo Powa Honda Civic / Del Sol (1992 - 2000) 8 08-05-2002 04:49 PM
Tags
1993, accord, acura, applied, applying, brake, brakes, click, clicking, engaged, honda, makes, making, noise, released, sound
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
