brake caliper
brake caliper
i have a 90 integra and i am changing the rear brake pads i was able to take off the pads but when i try to rotate clockwise the piston back into the caliper it wont turn, my question is will some wd40 do the trick or is the caliper shot?
Daisy... Daisy...
Re: brake caliper (funkeyone)
I don't think that penetrating oil will have a pathway to the adjusting screw behind the piston. Have you tried to rotate it CCW as well? Perhaps you can free the piston by switching directions and then turn it CW.
You can see the parts here.
http://www.acuraparts247.com/p...ch=no
Kevin Nealis
04-19-2015 07:53 PM
