bent valve?
Re: bent valve? (Tegraracer90)
loud ticking. or, in my case, the car wont start because all your exhaust valves are bent and all your valve guides are broken so the motor has 0 compression on each cylinder. the best way to test for a bent valve is to just run a compression check.
i did a compression test...all four cylinders had and held compression...but while i was doing that i noticed that the copper line for my oil pressure gauge was rattling against the alternator....which i think was the noise i was hearing inside the car...thinking it was the head...although the head still makes a slight knocking noise...but that has been going on for a while that i knew about....
You can tell if you have a bent valve after a mis-shift if; the car is having a poor idle, ticking sound, or if too many valves are damaged then the car won't even run/start. Do a valve lash adjustment to aid with the ticking sound.
Ex. one of my friends did the money shift on my car and I thought I had a bent valve because I heard a ticking sound from the head. After performing a valve lash adjustment the ticking sound was gone. The valve train is even quieter now then before.
Give it a shot.
Give it a shot.
Nisif
02-27-2008 06:06 PM
