beeping noise from the dash, not the stereo... what is it? - Honda-Tech
Old 08-15-2007, 06:08 PM   #1
fisofo's Avatar
Default beeping noise from the dash, not the stereo... what is it?
Hey guys, I just created an account because last week I started getting a strange beep noise coming from my dash. It beeps 1 to 3 times, then stops... it happened a few times in one day, then didn't make any noise for several days, then did it again twice in one day. Very strange! its happened when I'm on the freeway, while sitting at a light... doesn't seem to a rhyme to it. I'm almost positive it's not the stereo though, it's definitely coming from the driver side dash above the instrument panel.
Anyway, the car is a 90 Integra LS... I don't know much about cars unfortunately, so I could use the help. There are no other indicator lights on, I had it in for a check-up today and the mechanics couldn't duplicate it and didn't have any idea what it would be. Perhaps I'm starting to insane
I suppose I could just ignore it (although it's annoying) but I just want to make sure I'm not missing something important.
Thanks!
fisofo is offline   Reply With Quote
Old 08-15-2007, 06:45 PM   #2
Daisy... Daisy...
Dogginator's Avatar
Default Re: beeping noise from the dash, not the stereo... what is it? (fisofo)
Did you loan your car to an al Qaeda member?
This is nearly impossible to address with words. You simply need to listen and pinpoint it. Does the car ever make this beeping at other times?
Dogginator is offline   Reply With Quote
Old 08-15-2007, 07:18 PM   #3
fisofo's Avatar
Default Re: beeping noise from the dash, not the stereo... what is it? (Dogginator)
al Qaeda! Of course! I was wondering where my car was the past few days and why "DEATH TO THE AMERICAN INFIDELS!" was written on the hood when I found it. I suppose the bundle of explosives with a timer on it sitting on my dashboard should have tipped me off... man, how do I miss these things? Hindsight's 20/20 I guess.
Anyway. Well... I'll see if I can pinpoint it more, but it happens so infrequently that the chance of it doing it while I've got the hood up or something is pretty much zilch.
It sounds almost dead-center above the instrument panel in the dash (from memory). I just read in another forum that they had this noise when power steering was having trouble... but it was a different car and I'm not having power steering trouble. So I kinda doubt that's relevant.
I'll look around at the fuse box and search the web a bit more, any other suggestions would be appreciated though! Perhaps Leprechauns? Robotic Squirrels? Global Warming? j/k
I need some sleep.
Old 08-18-2007, 08:55 PM   #4
BCrawford's Avatar
ICU Integrated Control Unit. Causes strange beeping from behind fuse panel, int wiper settings not to work, and rear defroster problems.
BCrawford is offline   Reply With Quote
Old 08-18-2007, 10:04 PM   #5
fisofo's Avatar
Default Re: beeping noise from the dash, not the stereo... what is it? (BCrawford)
No... Flippin... way! Well, that makes perfect sense because my int wiper settings crapped out on me a few months back (I now have 3 speeds: stopped, slow, and fast... no interval), and my rear defroster has not worked since I was given the vehicle (couple years now).
So... I guess I'll search around on that ICU, I don't suppose it's cheap/easy to replace, is it? Perhaps I can rip one out of a similar model at a junkyard?
Old 08-18-2007, 10:12 PM   #6
1200 Hobos's Avatar
I get the same thing. Lol, at first it was hella wierd but I got used to it. Atleast now I know what it is, haha. My interval wiper setting doesn't work either, although I have no more wipers. 91 LS btw. I'm interested in the ICU fix aswell. Cheap/Easy? What needs replacing?
1200 Hobos is offline   Reply With Quote
Old 08-19-2007, 04:32 PM   #7
BCrawford's Avatar
Default Re: beeping noise from the dash, not the stereo... what is it? (theBRIANjonestownMASSACRE)
Quote:
You guys will love this if you don't mind playing with a soldering iron
http://www.g2ic.com/forums/showthread.php?t=127170
I did it earlier this afternoon and it worked like a charm. I had to bridge 2 corroded paths with small wires and replace a capacitor, but it only cost me about $10 which included a 7 dollar solder iron. lol
Old 08-19-2007, 06:50 PM   #8
fisofo's Avatar
this just made my day, i'll post on how it works when i have some time to do it.
Now if I could just get my A/C working... but I bet that's out of the question
95 Civic crank no start TYBG Honda Civic / Del Sol (1992 - 2000) 14 12-17-2016 08:53 PM
2014 CRV EXL Random Beep Noise Amy Nicholson Honda Element & CR-V 1 01-22-2016 07:20 AM
91 Civic Electrical Problems phil0975 Honda CRX / EF Civic (1988 - 1991) 3 02-24-2007 05:42 PM
beeping noise while im driving!!!!!! 92integraVTECgsr Acura Integra 6 10-20-2005 10:46 PM
Strange electrical problem with horn. Pressing it makes seat belt and door ajar lights flash. ~Long T_Rex Tech / Misc 0 06-20-2003 02:37 PM
Tags
2005, acura, beep, beeping, beeps, coming, dash, dashboard, install, integra, made, noise, radio, starting, stereo, tl
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
