ball joint with no cotter pins??? - Honda-Tech
Old 04-26-2006, 03:33 PM   #1
Silent_Destruct's Avatar
Default ball joint with no cotter pins???
i just got a ball joint today and it has no cotter pins, and the nut is different. also the rod that sticks out of the ball joint doesnt have a hole for a cotter pin...
so the only thing stopping it is the nut which has blue plastic on the end...?
confused on to why mine didnt have a cotter pin or the hole for one
Silent_Destruct is offline   Reply With Quote
Old 04-26-2006, 03:40 PM   #2
sik96teg's Avatar
Default Re: ball joint with no cotter pins??? (Silent_Destruct)
that blue thing basically locks the nut on so theres no need for a cotter pin but ive never seen that if your worried take it back
sik96teg is offline   Reply With Quote
Old 04-26-2006, 03:42 PM   #3
will it still lock it if ive un done it a couple of times? (replaced pass axle twice in 2 days...didnt know i had antilock, so i got the one without, found out i do, had to replace)
Old 04-26-2006, 03:47 PM   #4
sik96teg's Avatar
Default Re: (Silent_Destruct)
i would just get a few of the locking nuts so when u do take them off u can throw a fresh one on there. So yea replace the nut just to be on the safe side
Old 04-26-2006, 03:48 PM   #5
gotcha im guessing any sears or ace should have em
Old 04-26-2006, 03:52 PM   #6
sik96teg's Avatar
yea probably i usually get all my lil bolts like that from napa
Old 04-26-2006, 03:53 PM   #7
skunked's Avatar
they are called nylock nuts
skunked is offline   Reply With Quote
Old 04-26-2006, 03:54 PM   #8
thanks skunked....good to know!
Old 04-26-2006, 03:55 PM   #9
also which is better? cotter pin or nylock nut?
Old 04-26-2006, 04:01 PM   #10
sik96teg's Avatar
never seen a ball joint not use the cotter pin but if thats how there making some of them now it must be better or just as good. If i had to choose though i would choose cotter pin. Not that i dont doubt the nylock but y change a good thing
Old 04-26-2006, 04:02 PM   #11
skunked's Avatar
Quote:
I think the cotter pin is safer....
my friend hit a tree at 50mph because he didn't think the cotter pin was important. Not even 10 minutes it lasted on a curvey road.
Old 04-26-2006, 04:25 PM   #12
yea ur friend also had the standard nut though u know?
Old 04-26-2006, 04:47 PM   #13
skunked's Avatar
right, but my point was to tell what can happen if it comes off
Old 04-26-2006, 06:08 PM   #14
ya...that wouldnt be good, im thinking about putting a couple on just to be safe
Help for Accord 1994 Upper Control Arm/Balljoint/ABS faran Honda Accord (1990 - 2002) 11 12-20-2010 06:44 AM
jam nut / cotter pin BigWorm85 Suspension & Brakes 7 08-08-2007 11:39 PM
cotter pins posHonda Acura Integra 3 03-24-2007 08:36 PM
do i need cotter pins for ball joints and tie rods? SL!M Honda Civic / Del Sol (1992 - 2000) 17 06-08-2003 06:57 AM
Cotter Pin Question martilafox Tech / Misc 7 03-17-2002 03:02 PM
Tags
ball, blue, carter, cotter, important, integra, joint, lower, needed, nut, nylock, pin, pins, thing, upper
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
