Bad Spark plugs and spark plug wires makes tapping noise??
Old 10-22-2006, 05:38 PM
B20inDCinLBC's Avatar
Default Bad Spark plugs and spark plug wires makes tapping noise??
If your spark plugs or spark plug wires are bad, would it make a tapping noise. Something that sounds like it needs a valve adjustment?
Old 10-22-2006, 07:44 PM
* B A N N E D *
GRAF-FITI's Avatar
Default Re: Bad Spark plugs and spark plug wires makes tapping noise?? (B20inDCinLBC)
normally faulty wires and plugs will cause a misfire and some arcing...as for the noise i would recommend a valve adjustment as you questioned in your post
Old 10-22-2006, 08:06 PM
valve job was done, and still some tapping
Old 10-22-2006, 08:42 PM
ejmatzell's Avatar
Default Re: (B20inDCinLBC)
not to steel from your thread... but when you did your valve adjustment, (not to sound like a ricer) did you notice a power gain? i really need to get one done...
Old 10-22-2006, 08:46 PM
__oversea's Avatar
Default Re: (ejmatzell)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ejmatzell &raquo;</TD></TR><TR><TD CLASS="quote">not to steel from your thread... but when you did your valve adjustment, (not to sound like a ricer) did you notice a power gain? i really need to get one done...</TD></TR></TABLE>
lol.
it just make car run smooth like new. should be checked every 40-50k miles. not really sure about mileage
Old 10-22-2006, 09:54 PM
no, didn't notice HP gain, just got rid of the annoying tapping sound though. I can't notice any power because right now it's untuned.
Old 10-23-2006, 08:28 AM
ejmatzell's Avatar
^ gotcha, thanks
Old 10-23-2006, 08:31 AM
skunked's Avatar
If you have a bad wire it will make a ticking sound as it arc's off whatever it's grounding to. Like others said, it will run very rough as well. At night it will look like Star Wars under your hood if that was the case
Aftermarket header's will also create a louder "ticking" sound from the motor which is normal.
Old 10-23-2006, 05:49 PM
where would the light show come from though?
Old 10-24-2006, 07:36 AM
skunked's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20inDCinLBC &raquo;</TD></TR><TR><TD CLASS="quote">where would the light show come from though?</TD></TR></TABLE>
from wherever the wires are arching if that's the problem.
edmfactory
06-19-2012 05:55 PM
Ritchie
03-23-2011 02:52 AM
mynameizstitch
06-10-2009 07:17 AM
dynamitezz
10-28-2006 08:07 PM
accordisslow
01-05-2006 07:09 PM
Quick Reply: Bad Spark plugs and spark plug wires makes tapping noise??
