bad smell from the air vents
Old 07-12-2002, 09:15 AM
csfalcon's Avatar
Default bad smell from the air vents
Hi,
It started early this summer, when ever I put the air vents on "fresh" I get this bad smell coming out of them. It smells like a mixture of sweat and urine I have noticed if I have recirculate and AC on the smell eventually goes away, but on "fresh" it is always there. Where should I clean? Thanks.
Old 07-12-2002, 09:26 AM
New User
IC x Prince's Avatar
Default Re: bad smell from the air vents (csfalcon)
Maybe try to let it run for awile in fresh. Mine does it also when I haven't run my AC for awile.
Old 07-12-2002, 09:30 AM
Eva01's Avatar
Cant really clean where the smell is coming from. What is causing that smell is when using your air conditioner, condensation builds up water in the AC system. Since this is basically a closed system, the water is not able to evaporate giving mold and bacteria a chance to stagnate the water...causing that funky smell. Same thing that happens when you leave a wet towel bundled up on the floor and it starts reeking after a day or two. The only thing you can do is run the fan until the water evaporates and that should get rid of dat' funky smell!
Old 07-12-2002, 09:39 AM
csfalcon's Avatar
Default Re: bad smell from the air vents (Eva01)
Thanks guys! That sounds very nasty, going to run the fan till the system is dry.
metalmole
Honda Civic (2001 - 2005)
06-18-2014 10:30 PM
itgrowsind
10-21-2013 12:18 PM
Revolver123
06-12-2008 03:08 PM
Mike813
09-05-2003 11:25 AM
GruvyTune
08-02-2002 05:27 PM
Quick Reply: bad smell from the air vents
