b18c1...how much oil.
First off, I would have searched but OIL, is too short of a word to search for.
I just finished my b18c1 swap..I put in four quarts and it seemed low...I have over 4 quarts in now and I'm maybe 1/2 quart high..
What is the amount of oil needed when you do a full change including filter?
Thanks.
Thanks.
Re: b18c1...how much oil. (NA gs-R 05 C)
i usually put in 4.5, with 4.5 it puts the level at the top dot on the dip stick, then when you start it up and get the oil flowing it usually settles in the middle of the 2 dots on the dip stick. this is on a B18c1
Re: b18c1...how much oil. (SilverB18C1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverB18C1 »</TD></TR><TR><TD CLASS="quote">i usually put in 4.5, with 4.5 it puts the level at the top dot on the dip stick, then when you start it up and get the oil flowing it usually settles in the middle of the 2 dots on the dip stick. this is on a B18c1</TD></TR></TABLE>
That's what I do. But lately my levels drop pretty good after a while. I gotta put another quart in. I think it's b/c my cam seals are leaking oil, but it could be more. I dunno
Re: b18c1...how much oil. (P1mpSlap)
Spec calls for 4.2 US Quarts.
I put in 4 quarts, start the car, run to solid idle, shut off, let sit for 5 minutes, check oil level and top off. Works like a charm and sits dead in the center of the two level marks. :D
Re: b18c1...how much oil. (B-Tuning.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B-Tuning.com »</TD></TR><TR><TD CLASS="quote">Spec calls for 4.2 US Quarts.
Re: b18c1...how much oil. (HXMan)
another trick is to take the valve cover breather hose, and blow on it, this will push a lot of oil out of the system. by doing this i blow a good .5 quarts of oil out that was stuck in the system
i usually put bout 4.5 cuase i tend to hit vtec alot and burns up my oil. if I put 4 and keep going at high rpm's 1-2 week, oil is below 2nd dot.
Re: b18c1...how much oil. (TeamTooQuick)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverB18C1 »</TD></TR><TR><TD CLASS="quote">another trick is to take the valve cover breather hose, and blow on it, this will push a lot of oil out of the system. by doing this i blow a good .5 quarts of oil out that was stuck in the system</TD></TR></TABLE>
Interesting.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamTooQuick »</TD></TR><TR><TD CLASS="quote">4.5 is perfect...i use nothing but Mobil 1 10w-30 synthetic in mine...</TD></TR></TABLE>
I used to do that in my old car, until I decided it is probably better for my engine and cheaper to just change the oil with Castrol GTX every 1.5k then change with mobile one every 3 or 4k.
Interesting.....
yeap there was a thread like this before
and he mentioned that he likes to
"blow"
LOL
"blow"
LOL
Re: b18c1...how much oil. (N T R Z R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by N T R Z R »</TD></TR><TR><TD CLASS="quote">
"blow"
LOL
lol
"blow"
LOL
lol
