B18C valve clearance
I want to check my valve clearance and replace the camshaft oil seals.
Does any one know the int. exh. valve clearances, and how much a sproket alignment tool costs?
* B A N N E D *
Re: B18C valve clearance (street rat)
Hello, welcome to honda-tech. Frequently asked questions like these are usually answered in the sticky at the top of this forum that says..... FREQUENTLY ASKED QUESTIONS
https://honda-tech.com/zerothread?id=462021 – Valve Adjustment Tools
https://honda-tech.com/zerothread?id=976005 – Valve Adjustment Temp
https://honda-tech.com/zerothread?id=303365 – Valve Adjustment, How To
Google helps too, I'm sure there would be thousands of results on "B18C1 valve clearance"
also its printed on a sticker under your hood. Good luck with the adjustment. Remember, make sure the motors COLD, and a little loose is better than a little tight.
