b18c swap CEL code 23
first off i have searched, and came up with many answers, im still not sure what to do
i just recently swapped in the b18c from my wrecked car (damaged rear) to my new car, im using the same engine, engine harness and ecu from the wrecked, it had no cel, but now its showing up when i swapped it, the car runs fine, just not as much torque as before, im guessing its the cel
CEL code 23 KNCOK SENSOR
i checked the sensor its pluged in right
wrecked car was a 94 ls swapped jdm b18c
new car is 94 gsr sedan
p73 ecu jdm
any help is apreciated
p73 ecu jdm
Re: b18c swap CEL code 23
another thing, vtec kicks in with the CEL but has no low rpm power, but when its off it has lower end power and no vtec, WHATS WRONG?!?!??!
same prob with this guy, but looks like he didnt fix it?
http://htarchive.org/showthread.php?t=1597103
id try replacing the knock sensor and un hooking the battery for a few minutes to reset the ecu / or u could always get a chipped p28 ecu with knock sensor disabled
found the problem, the engine harness pin was not in the correct pin for the chassis harness
hope this helps for future purposes
close thread
close thread
dpstang98gt
Engine Management and Tuning
10
05-15-2009 04:49 AM
b16a2-t *turbocoupe*
04-17-2006 01:04 PM
Mashimaro
02-15-2005 01:28 AM
