b18c specs?? - Honda-Tech
b18c specs??
Old 03-16-2009, 08:39 PM   #1
b18integraboy's Avatar
Default b18c specs??
ok im looking into buying a new motor for my car. i found a seller on hondamarketplace selling a jdm b18c. now it has a black valve cover so im asuming that its not a jdm type r and just a sir b18c. what is the specs and diffrences of this motor??
b18integraboy is offline   Reply With Quote
Old 03-17-2009, 04:51 AM   #2
Default Re: b18c specs??
Someone could have painted the valve cover easily. but if not..
Now i could be wrong because i don't have an "Sir" but if the code is b16a:
The spec's on the Sir would be - ( had to look it up )
Maximum power 170.3 PS (168.0 bhp) (125.3 kW)
@ 7800 rpm
Specific output105.3 bhp/litre
1.73 bhp/cu in
Maximum torque 157.0 Nm (116 ft·lb) (16 kgm)
@ 7300 rpmbmep 1236.9 kPa (179.4 psi)
Specific torque 98.43 Nm/litre
But i have a b18c type r:
The spec's on the JDM B18c Type R - (200hp, 137ft.lbs tq.)
My opinion, i love my motor. go with the type r if you want reliable,strong, & fairly quick. The sir on the other hand, honestly don't know much about it.. But it aint what other people want, its what you want to be driving.. my preference is quick but reliable and no boost because everything now days is boosted. all motor to me makes a how different feel.. but in the end, boost is where a lot of people wanta be.
96b18c-r is offline   Reply With Quote
Old 03-17-2009, 05:00 AM   #3
b18c
1797
10.6:1
180/7600
delbert is offline   Reply With Quote
Old 03-17-2009, 09:09 AM   #4
Quote:
Originally Posted by delbert View Post
b18c
1797
10.6:1
180/7600
x2
itr#1334 is offline   Reply With Quote
Old 03-17-2009, 09:20 AM   #5
thanks every one
Old 12-20-2010, 10:59 PM   #6
Quote:
Here are the Specs for a B18c
98+ Integra Type-R (JDM) B18C
98 Spec-R
* 1797cc
* 4 cyl, 16 valve
* DOHC VTEC
* 10.0:1 c.r.
* PGM-FI (MPFI)
210 bhp @ 8100
Redline: 8900 rpm 18.5Nm @ 7500
Jdm_King01 is offline   Reply With Quote
Old 12-20-2010, 11:48 PM   #7
racebum's Avatar
98 Spec-R
* 1797cc
* 4 cyl, 16 valve
* DOHC VTEC
* 10.0:1 c.r.
* PGM-FI (MPFI)
210 bhp @ 8100
not correct but probably not your fault. lot of bad information out there. the motor has 200hp, redlines at 8400 with fuel cut at 8700 and has 11:1 compression
racebum is offline   Reply With Quote
B18C5 ? blackjdmeg6 Acura Integra Type-R 8 01-12-2006 10:46 PM
2nd generation JDM B18C5 ? 12017717731 Honda Civic / Del Sol (1992 - 2000) 12 05-16-2005 08:32 PM
B18C3 Specs shorto85 Acura Integra 8 02-08-2005 04:54 PM
b18 specs ThatsMyEG Honda Civic / Del Sol (1992 - 2000) 7 10-24-2004 02:21 PM
stock rod lengths, strokes, and other specs. JDMorgan Tech / Misc 1 03-29-2004 09:33 PM
Tags
18c, 1998, 2000, b18, b18a, b18c, honda, integra, jdm, motorhonda, sale, sir, specifications, specs, type
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
