99 GSR, fuel pump sounds like it is priming/running all the time, help
Old 12-19-2010, 11:32 PM
JOE_DC4ever's Avatar
Default 99 GSR, fuel pump sounds like it is priming/running all the time, help
I did a GSR swap in my 94 integra (chipped p28). When the key is truned on, the fuel pump primes, but keeps running.. The car runs fine. What is causing this? Are my vacuum lines hooked up wrong? Electrical? Injectors? Ecu? Thank you!
Old 12-20-2010, 06:19 AM
fcm
Old Fart
fcm's Avatar
Default Re: 99 GSR, fuel pump sounds like it is priming/running all the time, help
If the pump keeps running, either there is a problem with the ECU/ECM, [it controls the fuel pump relay] or the PGM-FI Main Relay is not wired properly, it could also be that the fuel pump power is miswired. 04
Old 12-20-2010, 10:11 PM
Ok thanks, i will see if i cant get a different P28. And see if that fixes the problem.
boostedjd
Engine Management and Tuning
07-03-2013 06:05 PM
BucCivicSi99
01-10-2010 07:45 PM
ksbenjamin44
06-25-2009 05:22 PM
GDM S2K
Honda S2000
01-08-2007 01:30 PM
93FlatBlackHatch
12-30-2006 03:22 PM
Quick Reply: 99 GSR, fuel pump sounds like it is priming/running all the time, help
