B18b1 Timing light question.
Old 03-07-2014, 02:05 AM
carlos8's Avatar
Default B18b1 Timing light question.
hi guys, I'm working on this issue that the car choke and sputter when press the gas.
The time is on spot on the cams, but because I not have lower cover I removed the crank pulley and the oil pump arrow face the timing belt pulley.
My question where do I point the timing light? I was pointing from above the P/S pulley but it can be done from the side of the driver mount.
https://honda-tech.com/attachment.ph...1&d=1394190277
Old 03-07-2014, 05:15 AM
kyden's Avatar
Default Re: B18b1 Timing light question.
you can't do it without a lower cover. find a set and put it on.
Old 03-07-2014, 06:23 AM
carlos8's Avatar
Kyden, The Mechanical time is on spot, but when I jump the service connector and put the light I still see the TDC mark.
If I advance the dizzy complete the BTDC first groove come close to where I'm pointing but when remove the jumper the TDC mark isn't in point. It's like a 1/4" to the right.
90civic-ZC
11-23-2011 02:36 PM
hellaflushdb2
06-19-2011 05:13 AM
royalfelix
01-26-2009 08:08 PM
kixcrx
10-14-2007 11:09 AM
Dark_Helmet
01-12-2005 05:51 AM
Quick Reply: B18b1 Timing light question.
