b18a vs b18b - Honda-Tech
b18a vs b18b
Old 05-23-2008, 02:03 PM   #1
vegassinsation's Avatar
Default b18a vs b18b
i was woundering if someone can help me what is the difference on a b18a and a b18b
vegassinsation is offline   Reply With Quote
Old 05-23-2008, 02:53 PM   #2
Rickdrizzle's Avatar
Default Re: (Jimmy)
My buddies 93 Ls never came with the B18b.
My cousin's 92 Ls also never came with the B18b.
I believe the B18b only came in the 94+ Integras.
Modified by Rickdrizzle at 3:04 PM 5/23/2008
Rickdrizzle is offline   Reply With Quote
Old 05-23-2008, 02:59 PM   #3
mc-integra111's Avatar
Default Re: b18a vs b18b (vegassinsation)
Very close, but Honda screwed us a little with funny naming conventions.
B18A - 90-91 RS/LS/GS - 130 HP, OBD0
B18A1 - 92-93 RS/LS/GS - 140 HP (due to higher lift intake cam), OBDI
B18B - 94+ RS/LS/GS - 140 HP (same intake cam as B18A1), OBDII (as of 96)
FYI, the valvetrain parts are the same between the B18A and B18B. Also, B18A ECU's (PR4's) have been successfully used with B18B's (P75's I think), although for max power a tune is required.
mc-integra111 is offline   Reply With Quote
Old 05-23-2008, 03:02 PM   #4
Global Moderator
Jimmy's Avatar
Thanks for clearing that up.
I was ''questioning'' that information.. Cause none of my friends with Da tegs have either had B18B's.. either
I shall not return back to superhonda.
Jimmy is offline   Reply With Quote
Old 05-23-2008, 03:05 PM   #5
Default Re: b18a vs b18b (mc-integra111)
*sigh*
90-91 Integras were also b18a1.
Don't ask me how I know.
Jesus Christ, almost everyone I know has each year of the Integras.
Old 05-23-2008, 03:14 PM   #6
Default Re: b18a vs b18b (Rickdrizzle)
Quote:
Do they have a 90-91 block? I have a B18A stamp on mine (no 1 after it). I guess that could have been removed by a previous owner though. Interesting. Normally Honda/Acura did a good job with their engine codes, but the early DA's seem to have new quirks pop up all the time.
Old 05-23-2008, 03:18 PM   #7
I don't know about the 90, but another of mine had a 91. It had B18A1 stamped on it.
Old 05-23-2008, 03:20 PM   #8
Old 05-23-2008, 05:03 PM   #9
bmwpride's Avatar
90 has a b18a thats all and 91-93 a1
bmwpride is offline   Reply With Quote
Old 05-23-2008, 05:16 PM   #10
Default Re: (bmwpride)
Quote:
Do you have proof to back this up? Or are you simply talking out of your ***.
Old 05-23-2008, 06:42 PM   #11
Quote:
90-93 Integra RS, LS, LS SE, GS - B18A1
OBD-0 130hp 121lbs/torque
OBD-1 140hp 126lbs/torque
94-01 Integra RS, LS, LS SE, GS - B18B1
OBD-1 142hp 128lbs/torque
OBD-2a 142hp 128lbs/torque
OBD-2b 142hp 128lbs/torque
inspiration is offline   Reply With Quote
Old 05-23-2008, 07:49 PM   #12
PaChiLa Leader's Avatar
Default Re: b18a vs b18b (inspiration)
94-95 OBD1 --> i am not sure if this one has 142HP, oh well~
96-99 OBD2A
00-01 OBD2B
PaChiLa Leader is offline   Reply With Quote
Old 05-23-2008, 07:50 PM   #13
My 90 integra has B18A1 stamped on it. Yes its the original motor.
Rediness_code is offline   Reply With Quote
Old 05-24-2008, 12:55 AM   #14
outkast80's Avatar
i have a 1990 integ with a b18b jdm...and it has so much power its crazy...i beleive it has more tourq then the b18a..
outkast80 is offline   Reply With Quote
Old 05-24-2008, 01:47 AM   #15
I drive a G35, it's silver, surprised?
CARMA_626's Avatar
Default Re: b18a vs b18b (outkast80)
Quote:
LOL, well that came from left field....
CARMA_626 is offline   Reply With Quote
Old 06-16-2008, 06:56 PM   #16
sai_iii's Avatar
Question for you: I have a b18a1 swapped in to an ek hatch and it is currently running on a P2E ecu and I don't think that it is running very smoothly. Can I use an OBD2 P75 ecu with no issues?
sai_iii is offline   Reply With Quote
Old 06-24-2008, 10:18 AM   #17
sai_iii's Avatar
Does anyone know?
b18 oil pump question hillbilly Acura Integra 2 07-19-2009 10:47 AM
b18b compatible with b18a bara6075 Acura Integra 3 09-10-2007 06:21 PM
B18A/18B/20B engine specs gamakichi77 Tech / Misc 13 05-06-2005 08:37 AM
B18A Header fit the B18B?? superboy Acura Integra 8 12-23-2003 03:10 PM
b18a vs b18b b16 Honda Civic / Del Sol (1992 - 2000) 6 07-03-2003 07:33 AM
Tags
9091, acura, b18, b18a, b18b, ca, cam, difference, ecu, honda, hp, integra, lsgs, pr4s, redlands
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
