b17a1 valve clearance
Old 04-30-2013, 06:04 PM
handafreak2112's Avatar
Default b17a1 valve clearance
hello i just clayed my engine and i have clearance estimated 150 thousandths of an inch of clearance between the intake valve and the piston and about 170 thousandths between the exhaust valve and the piston, i clayed the engine with the vtec pins locked and i have b16b pistons alpha series valves and skunk2 pro series stage 2 cams im just wondering if this is enough clearance and i have a 3 layer head gasket
Old 04-30-2013, 06:12 PM
Blackhalo6's Avatar
Default Re: b17a1 valve clearance
Google it, but it sounds ok to me. Your talking 2 tenths of an inch almost.
Old 05-01-2013, 05:42 AM
okay man thanks any other help would be great these measurments were alsone taken
on hondas tdc for stock cams and stuff so i need to get them degreed then come back
i might have to go with a thicker head gasket but i dont want to do it because my compression is 13.3:1 but idk we will see i guess
Old 05-01-2013, 07:52 AM
Blackhalo6's Avatar
If this is the same car as the other posts, you need some fuel upgrades for 13:1. And don't just take my word for it. Look up clearance specs. I have a service manual, but its on my busted laptop so I can't check for you.
Old 05-01-2013, 08:30 AM
What fuel upgrades would it require ? Like injectors or like higher octane fuel?
Old 05-01-2013, 08:31 AM
Judge Owens's Avatar
Make sure you check when the engine is ice cold (:
Old 05-01-2013, 08:36 AM
Check clearances? The motor isn't even in the car so it's not gonna get hot
Old 05-02-2013, 05:39 AM
bump anyoine"?
Ac01031234
Engine Machining & Assembly
11-20-2016 11:36 AM
sugarfree135
09-22-2010 10:54 AM
wbaldwin_86
08-23-2009 04:30 PM
DougieFreshZero
Acura TSX
01-12-2009 05:29 PM
evildc2
07-31-2008 01:38 PM
Quick Reply: b17a1 valve clearance
