b series timing cover question...
Old 09-06-2006, 05:48 PM
POE
POE's Avatar
Default b series timing cover question...
ok i dont have the inner and outter top timing belt cover on my lsvtec... the head is a 92jdm b16.. Do i need to have the inner timing belt cover for the out timing belt cover to work?
anylinks or pictures would help!, thanks
Old 09-06-2006, 05:51 PM
Dartanian's Avatar
Default Re: b series timing cover question... (POE)
No, you don't need the inner portion. The outer portion bolts to the head without that piece.
Old 09-06-2006, 05:57 PM
POE
POE's Avatar
Default Re: b series timing cover question... (Sleeper Style)
thank you, do u have any links or picture to support your comment, i was told other wise by my friend who has the same part, and is lazy and doesn't want to take the cam gears off because of this...
thanks
atg1290's Avatar
Yeah alot of people remove the inner as it causes rubbing
Old 09-06-2006, 05:58 PM
POE
POE's Avatar
Default Re: (atg1290)
thanks, do u guys have any pictures or links that support this.. ? im searching as of right now.. thanks in advance
Old 09-06-2006, 06:02 PM
Dartanian's Avatar
Default Re: (POE)
I have this one. It is hard to tell, but the back cover is non-existent. I would take pictures now, but I don't even have the outer cover installed at the moment.
Old 09-06-2006, 06:05 PM
POE
POE's Avatar
Default Re: (Sleeper Style)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sleeper Style &raquo;</TD></TR><TR><TD CLASS="quote">I have this one. It is hard to tell, but the back cover is non-existent. I would take pictures now, but I don't even have the outer cover installed at the moment.
thanks for the picture.. what kind of motor is that lsvtec or what? and why is your outer cover off? how many Bolts do i need to buy? just 2 correct? will ones from a SOHC work?
Old 09-06-2006, 06:06 PM
B2FiNiTY's Avatar
Default Re: (POE)
Looks like sleeperstyle likes to show off his rusted stock cam gears
Old 09-06-2006, 06:07 PM
POE
POE's Avatar
Default Re: (POE)
this is what im working with right now, as you can see my valve cover is cut the same way.. and You can also see one bolt hole in the picture? so what is the purpose of the inner timing belt cover? and Why do so many people just take them off... i never heard of a rubing issue. If it was bolted down all the way. and not warped..?
Old 09-06-2006, 06:08 PM
POE
POE's Avatar
Default Re: (B2FiNiTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">Looks like sleeperstyle likes to show off his rusted stock cam gears </TD></TR></TABLE>
hey i just sold my adjustable ones and have my stockys on righ tnow too , they rock.
Old 09-06-2006, 06:11 PM
Dartanian's Avatar
I sure do...and I am proud of them.
It is a GSR. My cover is off because I just replaced my lost motion assemblies and forgot to put it on, and once I realized it, the valve cover was already put on and torqued down.
Old 09-06-2006, 06:14 PM
B2FiNiTY's Avatar
Default Re: (POE)
The purpose of the inner timing belt covers are to prevent exterior dirts and liquids from entering the chamber where the timing belt lies. Every little bit of safety adds up
Old 09-06-2006, 06:15 PM
POE
POE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">The purpose of the inner timing belt covers are to prevent exterior dirts and liquids from entering the chamber where the timing belt lies. Every little bit of safety adds up </TD></TR></TABLE>
It is a GSR. My cover is off because I just replaced my lost motion assemblies and forgot to put it on, and once I realized it, the valve cover was already put on and torqued down.</TD></TR></TABLE>
so to install this i will need to take my valve cover off, it looks like it just barely touch's it on the bottom 2 corners, if it even does.. sence mine is probably cut just a Little bit different than yours will i have any fitment issues?
Old 09-06-2006, 06:16 PM
POE
POE's Avatar
and on a SIDE NOT, thanks BTW, This head is from a 92 jdm b16, if i order a 99-00 si outcover, it will work correct?
Dartanian's Avatar
Default Re: (POE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by POE &raquo;</TD></TR><TR><TD CLASS="quote">so to install this i will need to take my valve cover off, it looks like it just barely touch's it on the bottom 2 corners, if it even does.. sence mine is probably cut just a Little bit different than yours will i have any fitment issues?</TD></TR></TABLE>
Yeah, it won't go in there unless the valve cover is off. I tried, but it won't snap into place.
Old 09-06-2006, 06:17 PM
POE
POE's Avatar
were does it snap into? the very bottom corners? i worried mine may not fit right, with the way its cut... may be off just a bit.. (thats my luck)
B2FiNiTY's Avatar
Default Re: (POE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by POE &raquo;</TD></TR><TR><TD CLASS="quote">and on a SIDE NOT, thanks BTW, This head is from a 92 jdm b16, if i order a 99-00 si outcover, it will work correct?</TD></TR></TABLE>
Yes.
You will need to order one from a gsr/b16/typer.
Old 09-06-2006, 06:18 PM
POE
POE's Avatar
Yes.
You will need to order one from a gsr/b16/typer. </TD></TR></TABLE>
ohh i thought the gsr's and type r's were a bit different than the b16's... shows how much i know..
Old 09-06-2006, 08:32 PM
POE
POE's Avatar
hmm i guess imgonna buy one, i hope i dont have to go for the inner also...
Old 09-06-2006, 08:40 PM
Dartanian's Avatar
Default Re: (POE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by POE &raquo;</TD></TR><TR><TD CLASS="quote">hmm i guess imgonna buy one, i hope i dont have to go for the inner also...</TD></TR></TABLE>
You don't really have to...unless you deal with a lot of gravel that may find its way up to the timing belt and wreck havoc on your timing belt. I have been running mine for well over a year without that inner piece (mainly because it was ripped to shreds somehow) and it hasn't had a problem yet.
Old 09-07-2006, 06:40 AM
POE
POE's Avatar
allright im gonna buy the outer piece hope you right boye...
will a SOHC timing belt cover bolt work on a DOHC?
and u got 2 u want to part with?
Old 09-07-2006, 03:17 PM
POE
POE's Avatar
ttt
bwebb111076
08-11-2008 03:34 AM
thizboii
04-21-2007 06:18 PM
POE
09-07-2006 03:16 PM
idriveadelsol7
12-18-2005 12:23 PM
216.226.142.95:27016
10-08-2003 10:01 AM
Quick Reply: b series timing cover question...
