Spacers on rpf1s.
Old 05-13-2011, 06:50 PM
ezcape's Avatar
Default Spacers on rpf1s.
I'm getting some rpf1s, they look alot better with spacers. Was wondering what would be a good length to get? Thanks.
Old 05-13-2011, 10:18 PM
theEGGmonsta's Avatar
Default Re: Spacers on rpf1s.
what size rpf1's and what offset are you getting?
Old 05-13-2011, 11:10 PM
TOO MUCH TORQUE's Avatar
i rub already with rpf1 35mm offset, adding spacers will be a disaster
Old 05-13-2011, 11:15 PM
^ depends on tires too, your tires look meaty though. im running +35 too on a 7.5 wide rim and i dont rub but im running 205/40 tires
Old 05-13-2011, 11:37 PM
yeah of course, these are 195/55/15 that came off my gsr blades. didnt want to spend money on 205/50/15. next set...
rubs like mad with people in there on right turns. also, my cambers settings are in factory spec, almost 0 degrees.
Old 05-13-2011, 11:45 PM
yeah i agree with you though...iono it all depends the op wasnt even specific about his height, his camber, what size rpf1s hes planning on...we still have no clue
Old 05-14-2011, 01:16 AM
lindapaul's Avatar
same problem any help please.........
Old 05-14-2011, 06:57 AM
PatrickGSR94's Avatar
spec isn't 0 degrees. That's why you're rubbing. If you were at more like -1.5° you probably wouldn't rub.
However I did used to scrape the frame rail seam under the front fenders with 195/55-15. I personally hate that tire size. I'll be going with 195/50-15 for my stock wheels next time.
OP don't use spacers. Get wheels in the offset you want to get the look you want.
Old 05-14-2011, 11:27 AM
patrick: i never said oem spec is 0 degrees, i said my camber settings are almost at 0 degrees. it ranges from -0.2 to -0.5 on at all corners.
195/55/15 is a comfy size, i personally wouldn't use 195/50/15 because its going to make the odo read too fast. 205/50/15 might be the best compromise.
Old 05-15-2011, 04:52 AM
Yeah I've had 195/50-15, speedo reads about 5mph fast on the interstate. Helps keep me out of trouble haha
shahriar35
12-16-2014 08:07 AM
mrtrinh
Honda Civic (2001 - 2005)
06-29-2006 04:59 PM
LSegHatchy
09-07-2004 01:42 PM
jweezy225
06-27-2004 09:51 AM
HUBB
28
10-06-2003 10:21 AM
Quick Reply: Spacers on rpf1s.
