Atomatic Seatbelt stuck on 90 Integra LS - Honda-Tech
Old 12-16-2003, 05:38 PM   #1
MaaseyRacer's Avatar
Default Atomatic Seatbelt stuck on 90 Integra LS
My buddies 90 Intergra LS, has automatic seatbelts that slide along the door jam, and just today, he opened the door after driving it, and the seatbelt grabbed him really tight, so then he close the door and turned the key the seatbelt went forward, and never came back. So now the seatbelt is stuck in the forward position, and will not come back so the shoulder harness is useless. Any suggestions on what to do to fix this? Has this happened to anyone before?
Thanks
MaaseyRacer is offline   Reply With Quote
Old 12-16-2003, 05:49 PM   #2
mEr
mEr's Avatar
Default Re: Atomatic Seatbelt stuck on 90 Integra LS (MaaseyRacer)
Yeah it happend to me, i own a 90' LS and i just broke the ****** off and got some 4-points!!
mEr is offline   Reply With Quote
Old 12-16-2003, 06:03 PM   #3
Default Re: Atomatic Seatbelt stuck on 90 Integra LS (Gen2B16)
take it to a dealer, they have to fix it
El_Jefe is offline   Reply With Quote
Old 12-16-2003, 07:57 PM   #4
Default Re: Atomatic Seatbelt stuck on 90 Integra LS (El_Jefe)
Quote:
Uh yeah it is a 1990, why would the dealer have to fix it, I we took it there, it would cost us a ton of money. So uh, I think I will pass on that one, anyone else have any suggestions, on what we should do? I like the 4 point thing and all, but this car is a daily driver.
Modified by MaaseyRacer at 6:05 AM 12/17/2003
Old 12-16-2003, 08:34 PM   #5
giff74's Avatar
I am getting ready to do the 4 point conversion in my 91, and its a daily driver, the suit is going to be a real b!tch.
giff74 is offline   Reply With Quote
Old 12-17-2003, 02:00 AM   #6
r34p3r666's Avatar
MAASEYRACER!!!!
From what i've gathered at http://www.g2ic.com, Honda/Acura is obligated to all seatbelt repairs (minus damage caused by an accident) for the life of the car........
r34p3r666 is offline   Reply With Quote
Old 12-17-2003, 02:31 AM   #7
brinks's Avatar
should be a tool in the toolkit to retract the belt to the rear. Check the 7.5a fuse under the hood.
brinks is offline   Reply With Quote
Old 12-17-2003, 06:14 AM   #8
JDM_Honda_Fiend's Avatar
Default Re: Atomatic Seatbelt stuck on 90 Integra LS (brinks)
You should be able to retract the seat belt latch back to pillar bar area if you pop open the bottom pillar cap. Same thing happened to my DA, so I just retracted it back and unplugged the seat belt sensor so that it would eliminate that annoying sound alerting you that your seatbelt isn't on.
JDM_Honda_Fiend is offline   Reply With Quote
Old 12-17-2003, 11:06 AM   #9
hondahans's Avatar
Not a soulution, but something I have wanted to post for a while. My previous car was a 90 LS with a B16 and I had gutted it to the point of no sound deadening or anything at all. just the dash remained. I have always hated auto belts, so I figured how to use my rear seatbelts as my main belts. There are holes on the frame and B pillar that accomidate these belts.(maybe RS' ?) The end result was full functional retracting belts that were not only lighter, but extremely more comfortable than the autos.
-Sorry about the thread jack.......good luck with the repairs.
hondahans is offline   Reply With Quote
91 sedan seatbelt help dubyas1989 Honda CRX / EF Civic (1988 - 1991) 8 06-29-2013 01:07 PM
Seatbelt buckle caught, Door stuck mataliandy Honda Accord (1990 - 2002) 4 07-12-2010 07:24 PM
I HAVE A REAL SEATBELT PROBLEM blzy415 Honda CRX / EF Civic (1988 - 1991) 7 09-24-2008 06:40 PM
'90 Integra GS power seatbelts I love my DB1 Acura Integra 3 05-07-2007 09:32 PM
Automatic seatbelt question! billybong91DA Acura Integra 1 03-13-2004 10:11 AM
Tags
90, auto, automatic, bealt, belt, foward, fuse, honda, integra, issue, ls, seat, seatbelt, sensor, stuck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
