Annoying Noises coming out of Glove BOX when heat is turned on?? - Honda-Tech
Old 03-04-2002, 11:26 PM   #1
New User
Default Annoying Noises coming out of Glove BOX when heat is turned on??
It is going worse and worse..when i turned on the heat...
the noise have been becoming louder and louder from the glove box,
i am not sure it's from the inside of glove box or beneath....
What could be wrong?
Any Idea?
thx a lot...
chi@1001 is offline   Reply With Quote
Old 03-04-2002, 11:29 PM   #2
ALF
ALF's Avatar
Default Re: Annoying Noises coming out of Glove BOX when heat is turned on?? (chi@1001)
I think I have the same problem as you. I've pretty sure it has to do with the fan.
ALF is offline   Reply With Quote
Old 03-04-2002, 11:31 PM   #3
Default Re: Annoying Noises coming out of Glove BOX when heat is turned on?? (Dozed)
The fan is right behind it.
Chris is offline   Reply With Quote
Old 03-05-2002, 04:35 AM   #4
Pineapple Devil's Avatar
Default Re: Annoying Noises coming out of Glove BOX when heat is turned on?? (Chris)
does it sound like a ticking noise? i've got one coming from my dash/glovebox.
Pineapple Devil is offline   Reply With Quote
Old 03-05-2002, 10:32 AM   #5
New User
Default Re: Annoying Noises coming out of Glove BOX when heat is turned on?? (Pineapple Devil)
yes, you guys are right the sounds of fan went louder and
louder.
and I also got the ticking noise as Pineapple Devil does.
so what should i do?
can i fix this myself? or i should take it to a shop?
thx
Old 03-05-2002, 11:20 AM   #6
BSQ
BSQ's Avatar
You probably have something in your fan. I had a leaf get sucked into mine before. You will just need to unbolt the fan (3 bolts if I remember correctly), which is behind the glove box, and see what is caught in your fan.
BSQ is offline   Reply With Quote
Old 03-06-2002, 04:27 AM   #7
Default Re: Annoying Noises coming out of Glove BOX when heat is turned on?? (BSQ)
all i know is its damn annoying. this afternoon im going to pull the glove box out and see what it is. i have to turn the radio up just to drown it out. i'll post and tell you if it fixes it or not
Old 03-06-2002, 08:33 AM   #8
JMX
JMX's Avatar
it was a was a leaf in mine...i just turned it off and then on high a couple of times and it got rid of the obstruction itself
JMX is offline   Reply With Quote
Old 03-06-2002, 09:57 AM   #9
Default Re: Annoying Noises coming out of Glove BOX when heat is turned on?? (jmx2323)
Ya my fan did that too. It was a leaf stuck in it. just mess with the power settings low to high eventually it will suck through. or you can take your vent assembly apart and pull whatever is in there out. If thats not the case then you might need to realine your fan bacause its rubbing on a side. Happened in my old car. I just added a washer and it worked fine after that.
Fooser is offline   Reply With Quote
Old 03-06-2002, 01:30 PM   #10
sean96gsr's Avatar
This story is actually kinda funny, but I had the same problem. There was a VERY annoying ticking type noise coming from the vents, and a vibration from behind and under the glovebox, and it got louder when you turned the fan higher. I figured it was a leaf, but I fooled around with it for a while and it didn't go away, and it lasted about a month before I brought it to the dealer and had them take a look at it. Somehow chipmunks had been getting into my garage, and they had been putting acorn and peanut shells into my fan cage....so on the paperwork it said "removed nuts from fan cage" and they charged me 35 bucks for it. If you can do it yourself, save the money, there's probably a leaf in your fan.
sean96gsr is offline   Reply With Quote
Old 03-06-2002, 01:33 PM   #11
Default Re: Annoying Noises coming out of Glove BOX when heat is turned on?? (sean96gsr)
chipmunks!
SonicGSR is offline   Reply With Quote
Old 03-06-2002, 02:52 PM   #12
PaChiLa Leader's Avatar
Default Re: Annoying Noises coming out of Glove BOX when heat is turned on?? (SonicGSR)
i thought it only happened to G2's
....... um.. weird
PaChiLa Leader is offline   Reply With Quote
Old 03-07-2002, 04:16 AM   #13
Default Re: Annoying Noises coming out of Glove BOX when heat is turned on?? (PaChiLa Leader)
I pulled the glove box out and looked and didnt find anything. Mine sounds more like its coming from the vent beside the windshield.
Humming noise saintx94accord Honda Accord (1990 - 2002) 1 08-16-2016 05:56 PM
What say you about gloves Carlo General Discussion and Debate 9 10-17-2011 08:14 PM
Help with HVAC System BeardBolt Acura Integra 0 09-17-2007 08:27 AM
00 civic si, Horrible high pitch howl coming from pass side engine bay. TommyTom83 Honda Civic / Del Sol (1992 - 2000) 6 11-23-2004 09:14 PM
EG Tranny problem..pls help verseone Honda Civic / Del Sol (1992 - 2000) 5 03-03-2003 11:12 AM
Tags
2000, accord, box, car, causing, chipmunk, compartment, fit, glove, glovebox, heat, heater, higher, honda, louder, noise, ticking, turned
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
