Announcements in Forum : Acura Integra
05-14-2009 until 12-30-2049
PatrickGSR94
PatrickGSR94's Avatar
►►►►►Frequently Discussed Topics in the Integra forum -- SEARCH FIRST!◄◄◄◄◄
I have seen quite a few threads come up lately about the same few topics. It seems like some of these same topics crop up as new threads on a weekly basis, sometimes even more often than that. These are some of the general topics I've noticed:
Frequently Discussed Topics:
  • Any super-broad topic (i.e. What should I buy for my car?) with little to no additional info
  • Engine Oil Recommendations (viscosity, brand, drain interval, etc)
  • Transmission Fluid Recommendations (type, brand, drain interval, etc)
  • Other general maintenance recommendations
  • Fuel Economy
  • Fuel Recommendations
  • 98+ Front End Conversion
  • JDM Front End Conversion
  • Maintenance Required Light
  • ITR Wing Installation (covering the holes)
  • Any performance part suggestion without specific information about the vehicle, its intended use, other upgrades, etc.
If you have a question regarding one of these topics, SEARCH first! A search for any of these topics will return TONS of results. If you find an existing post and wish to comment, feel free to do so, with the understanding that bumping an old thread may cause your particular question to go unnoticed. Otherwise, make a thread with a SPECIFIC question or comment. Please do not make a thread with the same general topic that has been posted thousands of times already. Any such threads will be locked.
Also, feel free to reply to a thread you found through searching if you need more information not covered in that thread or others. Again, this is with the understanding that adding to an old thread may cause your reply to go unnoticed as others may focus on the original post of the thread. If your question relates to other threads, but you feel it would be better asked in a new discussion, it's always helpful to post links to the other threads you already found. That will give equal attention to both your question and other similar topics like it.
NOTE: This is not an exhaustive list. If I think of any more I will be adding them to this list.
__________________
Please do not PM me with technical questions. Create a thread in the appropriate forum.
H-T OG member #8927 class of '02 ● Koni + GC InstallHID retrofit club
member #0001
PatrickGSR94 is offline
Forum Jump
