alternator or voltage regulator?!?!?
Old 04-12-2016, 02:40 PM
chip102's Avatar
Default alternator or voltage regulator?!?!?
Hey all,
Over the past year i have been fixing up a 91 LS that i rescued from its 7 year garden grave. It has devoured 2 batteries. I checked alternator and it was charging good but discovered a parasitic drain. After much frustration I narrowed it down to that stupid bumper on brake peddle being missing. Fixed that and no more drain. Then the ECM fried from water so I had to replace that and fix cowl. Now the car is dry and water proof again. Now as of yesterday a massive battery drain is back and the battery is fried. The alternator is putting out 16.5V at idle and the battery drain stops when I disconnect the alt. in wire from under hood fuse box.
My questions are these. First, is the voltage regulator internal or external? All the replacement alternators I have looked at say internal but that finned silver box on drivers strut tower is labeled at voltage regulator. Second. Is my overcharge issue a result of the alternator or that separate "voltage regulator"? Any tests I can perform to confirm?
Thank you!
Old 04-12-2016, 04:04 PM
TheRealTegger's Avatar
Default Re: alternator or voltage regulator?!?!?
That's the injector resistor, not a voltage regulator.
Your alternator has an internal voltage regulator.
If disconnecting the alternator connectors cures the drain, then the alternator is shorted internally.
Old 04-13-2016, 08:04 AM
fcm
Old Fart
fcm's Avatar
Ditto the above^^^, the voltage regulator in the alt. is toast, 16.5V is way too high, should be more like 14.5V. 94
Old 04-14-2016, 12:15 PM
chip102's Avatar
thanks all.
Speed--Freak
15
01-05-2022 05:22 AM
Lance Baker
Honda CR-V & Element
12-05-2021 06:55 PM
Annihilator
10-14-2009 04:55 PM
lmike6453
01-16-2009 06:55 PM
E_F_9
09-25-2007 01:11 PM
Quick Reply: alternator or voltage regulator?!?!?
