switchin oil pans. should i get new gasket?
Old 08-20-2006, 02:37 PM
J.nguyen's Avatar
Default switchin oil pans. should i get new gasket?
swappin over my B20 motor thats bad to jdm Ls motor and switchin the oil pans b/c its already tapped for the oil return line and also its a GSR oil pan. wondering do i HAve to GET new OEM gaskets? b/c mine isnt leaking but im hearing i have to get new gasket for it.. im kinda short on money and unemployed , just have enough money to swap it in and get new axles.. wondering would u recommend gettin new gasket and how much would it cost and what is it called. the "oil pan gasket kit" ?
Old 08-20-2006, 02:43 PM
Comp97GSR's Avatar
Default Re: switchin oil pans. should i get new gasket? (Jesse.)
Its a judgement call. If it is smashed/squished bad then it would need to be replaced. IMO, I would just replace it. I think they run about 20 from the dealer.
Old 08-20-2006, 02:46 PM
iH8RICERZ's Avatar
Default Re: switchin oil pans. should i get new gasket? (Comp97GSR)
I would just replace it so you don't run into any other problems, which would probably cost more money in the long run. Play it safe and replace it while its off
Old 08-20-2006, 02:47 PM
PrinceAli132's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iH8RICERZ &raquo;</TD></TR><TR><TD CLASS="quote">Play it safe and replace it while its off</TD></TR></TABLE>
x2
It should be around 20 bucks for a new gasket.
Ali
Old 08-20-2006, 02:48 PM
J.nguyen's Avatar
Default Re: switchin oil pans. should i get new gasket? (PrinceAli132)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrinceAli132 &raquo;</TD></TR><TR><TD CLASS="quote">x2
Ali</TD></TR></TABLE>
ic, koo then. didnt noe how much it cost. was thinkin around 50-60. but 20 sounds good
Old 08-20-2006, 03:23 PM
teg racer 877's Avatar
when I pulled my pan off my gasket was still very good shape (motor is a 2001) and didn't need to be replaced, doesn't leak at all either.
Old 08-20-2006, 04:44 PM
J.nguyen's Avatar
Default Re: switchin oil pans. should i get new gasket? (teg racer 877)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teg racer 877 &raquo;</TD></TR><TR><TD CLASS="quote">when I pulled my pan off my gasket was still very good shape (motor is a 2001) and didn't need to be replaced, doesn't leak at all either.</TD></TR></TABLE>
ic.. but wondering which oil pan gasket should i get? B18C1 since its a GSR oil pan or a LS b18b1 . or are they all the same?
Old 08-20-2006, 04:46 PM
In-N-Out Burger
NightRiderS2K's Avatar
GSR oil pan gasket.
Old 08-20-2006, 04:48 PM
J.nguyen's Avatar
Default Re: switchin oil pans. should i get new gasket? (NightRider-gsR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NightRider-gsR &raquo;</TD></TR><TR><TD CLASS="quote">GSR oil pan gasket.</TD></TR></TABLE>
ok just making sure. the OIL pan is a GSR and the block is an LS so i get an GSR oil pan gasket kit not an LS oil pan gasket kit correct
Old 08-20-2006, 05:15 PM
Comp97GSR's Avatar
I believe all B-series oil pan gaskets are the same.
Old 08-20-2006, 09:01 PM
J.nguyen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Comp97GSR &raquo;</TD></TR><TR><TD CLASS="quote">I believe all B-series oil pan gaskets are the same. </TD></TR></TABLE>
can i get a confirmation please?
94 IntegraLS
05-07-2013 11:42 AM
miro_gt
06-24-2007 08:02 AM
4DRmafia
02-06-2007 12:04 AM
IntegraB18A
12-20-2003 08:18 PM
jdmcivicek
09-17-2002 11:45 PM
Quick Reply: switchin oil pans. should i get new gasket?
