AEM Big Brake kit, what direction do the rotors go? - Honda-Tech
Old 02-25-2004, 12:52 PM   #1
hypa's Avatar
Default AEM Big Brake kit, what direction do the rotors go?
Which of these pics better shows the direction that the AEM big brake kit is supposed to travel?
A:
or
B:
hypa is offline   Reply With Quote
Old 02-25-2004, 01:05 PM   #2
Default Re: AEM Big Brake kit, what direction do the rotors go? (hypa)
from what ive seen the slots should be angled towards the caliper they are moving towards, if A is a picture of the front passenger side rotor then I believe that is correct, but im sure that people use them both ways, i would just think that would work best, maybe it doesnt matter that much in reality though
MajorPayne is offline   Reply With Quote
Old 02-25-2004, 01:28 PM   #3
hypa's Avatar
I was thinking that too.
Almost like a Skilsaw.
That't the way I've installed them, but if anyone else knows a better way, let me know.
Old 02-25-2004, 02:57 PM   #4
slomob18b's Avatar
Default Re: (hypa)
I think B looks right if thats the front driver's side rotor.
slomob18b is offline   Reply With Quote
Old 02-25-2004, 08:54 PM   #5
Boofster's Avatar
Default Re: (slomob18b)
Boofster is offline   Reply With Quote
Old 02-25-2004, 11:09 PM   #6
The slots are supposed to to angled towards the brake pads. This helps the rotor dissapate heat better. When you do get the AEM brake kit then it should have info on where each goes.
Spartanic is offline   Reply With Quote
Old 02-25-2004, 11:14 PM   #7
Default Re: AEM Big Brake kit, what direction do the rotors go? (Spartanic)
ok ok, i retract my previous statement, got to thinkng about it and the way this last pic is does seem to be right, so the gases can escape better, although i dont like the idea of slotted rotors to begin with, esp if you have slotted brake pads, but this topic has been beat to death, and i dont wanna get all up into that shiat again
Old 02-26-2004, 10:09 AM   #8
hypa's Avatar
hmmmm.....
so the "B" pic, with the slots going towards the pads is correct?
As for the AEM paperwork, I haven't found anything regarding directio of the rotors. Shitty assed brake kit....
Old 02-26-2004, 10:25 AM   #9
hypa's Avatar
Default Re: AEM Big Brake kit, what direction do the rotors go? (MajorPayne)
Quote:
I underatand that with today's anti-gassing technology in brake pads, that slots and cross drilling really aren't going to do anything. Given the choice though, I'd rather have a slotted, than a cross drilled.
Old 02-26-2004, 11:18 AM   #10
APEX i GSR's Avatar
hope this helps
APEX i GSR is offline   Reply With Quote
Old 02-27-2004, 08:48 AM   #11
hypa's Avatar
Default Re: AEM Big Brake kit, what direction do the rotors go? (APEX i GSR)
Quote:
Originally Posted by APEX i GSR
hope this helps
It helps a lot.
Thanks APEX i.
Old 02-27-2004, 09:57 AM   #12
Devlins 91LS's Avatar
In the first two pictures, they're both installed the same way, the caliper is just on the other side of the rotor, and both correctly. The black one with them going the other way is incorrect, as previously stated, the inside of the slant should hit the caliper first.
Devlins 91LS is offline   Reply With Quote
Old 02-27-2004, 09:59 AM   #13
dc-lefty's Avatar
Default Re: AEM Big Brake kit, what direction do the rotors go? (Devlins 91LS)
does the aem brakes clear 16's ??
dc-lefty is offline   Reply With Quote
Old 02-28-2004, 11:00 AM   #14
hypa's Avatar
Default Re: AEM Big Brake kit, what direction do the rotors go? (dc-lefty)
They clear my Black Racing Phantom's no problem.
I hear they also clear Rota wheels, and some Konig.
Old 02-28-2004, 11:50 AM   #15
IntegraBoy04's Avatar
I was told that they clear all 16s.
IntegraBoy04 is offline   Reply With Quote
Old 02-28-2004, 12:17 PM   #16
Chuck Norris's Avatar
Default Re: AEM Big Brake kit, what direction do the rotors go? (IntegraBoy04)
from my understanding the big concern is NOT the slots of the rotor face so much as it is the direction of the vanes inside the rotor. i'd definitely email AEM before tearing up that setup at a track.
Chuck Norris is offline   Reply With Quote
AEM Performance Eletronics Blowout! NoLimitMotorsport Miscellaneous - Appearance - Lighting 141 01-05-2017 11:39 AM
Big Brake back to stock Vspronk Honda Civic / Del Sol (1992 - 2000) 5 08-28-2015 12:56 PM
BRAKE JOB -- Hawk, Performance Friction, Ferodo, Porterfield, SP Performance, ETC Innes Wheels, Tires, Brakes, and Suspension 262 07-26-2015 12:09 AM
brembo big brake kit (5lug) trade? TURBOFTW For Sale 10 05-05-2014 05:56 PM
T1 Cam Trigger Setup Review and Instructions Mase Forced Induction 75 03-22-2014 02:28 PM
Tags
aem, big, black, brake, brakes, dicerction, direction, directional, go, honda, kit, rotors, sloted, slotted
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
