Adjusting the clutch
Old 09-28-2002, 04:51 AM
sshaikh01's Avatar
Default Adjusting the clutch
How do you adjust the clutch pedal on a hydraulic clutch.
btw its a 95 integra.
Old 09-28-2002, 06:19 AM
sshaikh01's Avatar
Default Re: Adjusting the clutch (sshaikh01)
can you even do it on a hydro clutch
Old 09-28-2002, 09:38 AM
sshaikh01's Avatar
i know that you know
Old 09-28-2002, 01:45 PM
sshaikh01's Avatar
waaaaaa waaaaaaa
waaaaa
waaaaaa
Old 09-28-2002, 03:08 PM
New User
vteg's Avatar
There is adjustment for it, but why do you need to? The clutch will adjust it self most of the time. The clutch can be adusted up which will give you more travel on the secondary. If you look at the clutch pedal assembly, you will find it. It is hard to explain/describe. All you need is a large open end wrench(14mm or 17mm).
Old 09-28-2002, 03:48 PM
sshaikh01's Avatar
Default Re: Adjusting the clutch (vteg)
O so there is a screw which i turn for hydro clutch.
thanks.
actually the reason i need it is because, just got a brand new clutch and flywheel installed and the clutch meeting point is very far.
I have to let the clutch go a bit more than half way to meet the enguagment point.
so i want to change that.
where is the screw to adjust the clutch ???
Old 09-28-2002, 07:17 PM
farmer floyd's Avatar
that is great for racing . so you just tap your clutch and not clear to the floor.. loteasier on your trans also not going to tear up a gear this way. Just so the throw -out bearing is not going around.
meece0927
07-02-2013 08:15 AM
Haarstad
06-24-2012 09:50 PM
Brett
11-15-2002 01:18 AM
Quick Reply: Adjusting the clutch
