Added a third can of R134a did I put too much? - Honda-Tech
Old 10-03-2003, 05:00 PM   #1
Default Added a third can of R134a did I put too much?
I added a third can in and immediately the compressor goes on and off every 5 seconds. I should note that the car had been running for 1 hour and with the turbo was very hot. The A/C probably wouldnt have gotten cold anyways when I tried it. But did I hurt something? should I just let it cool down and try it again? should I let some out if it does it again? How much do I know to let out?
AlphaKennyWun is offline   Reply With Quote
Old 10-03-2003, 05:20 PM   #2
Xumarius's Avatar
Default Re: Added a third can of R134a did I put too much? (S03Burner)
Putting too much r134 can screw up your compressor. Release some of it while you can.....
Xumarius is offline   Reply With Quote
Old 10-03-2003, 08:26 PM   #3
Default Re: Added a third can of R134a did I put too much? (Xumarius)
i released some and it got better.
Transmission codes, main relay clicking, no start duh09 Honda Civic / Del Sol (1992 - 2000) 2 04-17-2014 08:14 PM
1997 Civic CX S40 trans/clutch issues... hyperblu Honda Civic / Del Sol (1992 - 2000) 6 11-04-2011 01:33 PM
How much engine oil to use ina '99 4 cyl? Heat Honda Accord (1990 - 2002) 8 01-28-2011 06:07 AM
Just got tuned... _Cyclone_ Forced Induction 7 05-18-2005 10:58 PM
sick and tired of babying 3rd gear... h22a193 Honda Prelude 8 05-18-2003 03:57 PM
Tags
03, 134a, 2006, added, back, civic, honda, hurt, much, put, putting, r134, r134a, release, start
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
