act clutch problem
act clutch problem
ok heres the problem. i have a act organic clutch with a act extreem pressure plate and a fidanza flywheel. the problem is i can't get the car to go into gear. i can turn the car off put it in gear and start it then let off the e-brake while the clutch pedel is still pressed in and the car will start moving forward. now i have bleed the clutch out many many times. and i will bleed it for awhile and it will work. i will start the car and it will start working and go into all the gears but then once i drive it and go though all the gears and then try to downshift again it won't let me it will get stuck in nutral. can anybody give me any suggestions. please help thanx zack
Re: act clutch problem (zbower7)
Probably a problem with your clutch/pressure plate. It could also be a bad master/slave cylinder. Any leaks in your cylinders or lines? That's just a start.
Re: act clutch problem (Sack Master)
no problems with the slave cylinder. the pressure plate worked fine before i put the new clutch and flywheel in. i never had any problem with it before. i don't know how it would just stop working from setting around for 2 months
Why put a new clutch and flywheel in without changing the pressure plate? That COULD cause problems real fast. And check your master cylinder. A small leak will turn into a lot of lost pressure. How does your pedal feel? If it feels fine I'm guessing its something with the pressure plate.
the pressure plate was fine it just had alittle glaze on it so my local shop took that off i can't tell if i have any leaks but i couldn't tell that for sure. the peddle feels alright but maybe alittle soft still its been awhile since i pushed the clutch in like two months.
trus01d1er
11-12-2006 11:03 PM
