ac vent blocked ... ?
Old 08-05-2010, 01:37 AM
pKjai's Avatar
Default ac vent blocked ... ?
Recently had my passenger window smashed, and glass flew everywhere. I know a good amount fell into my vents on my dash.
I remember driving my car afterwards with the ac on, and everything seemed fine, but when I switched the ac to windshield defrost, and back to the vents, I heard a little crackle [like broken glass was moving around] coming from inside the dash, and my center console vents didn't blow any air at all anymore after [heater doesn't work either], no matter what setting I put it on, but the side vents still work, searched and found no results..
Any idea? How would I clean the glass out if it happens to be that the glass is blocking?
Old 08-05-2010, 06:01 AM
fcm
Old Fart
fcm's Avatar
Default Re: ac vent blocked ... ?
Glass has gotten into the heater box and binding up the mode control "doors", unfortunately it means a dash and heater box pull to remove the glass. 94
Old 08-05-2010, 06:08 AM
pKjai's Avatar
from what i've read, a dash pull shouldn't be too hard [though i've never had to do it yet], and i'll look up the heater box via haynes.
wouldn't have been such a big deal if it was my side vents, but the center console ac vents are the most important ones. lol, well anyway thanks for the info.
Old 08-05-2010, 04:45 PM
fcm
Old Fart
fcm's Avatar
Dash pulls on Honda/Acura is not so bad, hopefully you can access the inside of the heater box without removing it, if you have to remove the heater box you will have to recover the A/C refrigerant and recharge it after the reinstall. 94
silverdcteg
03-17-2010 07:10 AM
miguey310
21
01-22-2010 09:49 PM
DarkBB4
03-28-2007 08:07 PM
flat-blk-HB
06-08-2002 12:52 PM
w00dy82
11-27-2001 04:43 AM
Quick Reply: ac vent blocked ... ?
