96 Integra - no spark - Honda-Tech
Old 08-04-2009, 11:16 AM   #1
rmiller's Avatar
Default 96 Integra - no spark
Hi, I sure could use some help...I picked up a 96 Integra in which the timing belt was broken and I replace it and all the valves since many were bent. The guy I had picked the car up from already had the head out, but I believe I put everything back together OK along with new plugs.
Car cranks no problem but I can get any spark. I checked the coils according to the shop manual and troubleshooting flow charts and I have power to the distributor and just replaced the ignitor inside the distributor...still no spark.
I believe that the TDC sensor is built into the distrib, but don't really know how the spark gets generated. I imagine that the ECM is involved...so it's looking like it might be a bad ECM, but I'm not sure and don;t really want to put out the $$ if I don't have to.
Any ideas?
Thnaks in advance.
rjmiller
rmiller is offline   Reply With Quote
K Swap EG no spark RIZOBIZERT K Series 7 05-17-2015 09:44 AM
98 civic ex no spark cranking biggs21222 Honda Civic / Del Sol (1992 - 2000) 20 04-12-2015 08:15 AM
95 Civic DX - no spark or fuel. Is it the ECM? horseyj18 Honda Civic / Del Sol (1992 - 2000) 12 04-20-2014 06:52 AM
1996 Civic drive ability problem Stan Ski Honda Civic / Del Sol (1992 - 2000) 4 02-21-2010 02:08 PM
1996 Honda Civic problems Stan Ski Honda Accord (1990 - 2002) 9 02-21-2010 12:17 PM
Tags
95, 96, accord, acura, alot, bad, cranks, distributor, dont, ecm, honda, integra, plug, putting, spark, sparks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
