94 integra rear sway bar question
Hey guys I just ordered a rear type r 22mm Sway bar from hmotors... It came with the bushings and end links, but then I noticed it didn't come with the brackets.. stupid question but can I make the stock 14mm rear sway bar brackets work or will I need to purchase the 22mm brackets?
Re: 94 integra rear sway bar question
You shouldn't just bolt it on, with a Type-R rear sway bar (or any upgraded rear sway bar for that matter) you will ruin the subframe without a subframe brace, and that isn't an easy or cheap part to repair. Read these links, they talk about mounting it properly.
https://honda-tech.com/forums/acura-...ar-gsr-259297/
http://www.team-integra.net/forum/11...-subframe.html
On vacation
I've seen that repeated to death on here and elsewhere and it simply is not true if you aren't offroading your car or ignorantly using an extremely stiff RSB with extremely soft spring rates.
khronicboy420
Suspension & Brakes
15
03-25-2011 09:56 AM
Mikes2000civicsi
03-27-2008 09:02 PM
