'94 GS-R - high pitch noise from engine
Old 09-14-2010, 08:52 AM
taiwandiao's Avatar
Default '94 GS-R - high pitch noise from engine
Notice a high pitch noise coming from the engine bay in my '94 GS-R. I hear it intermediately, with and without A/C fan being on.
The best I can explain, it sounds like a high pitch whistle (or blowing into the top of a glass bottle). Hope that makes sense
I ruled out the radiator fans, as I have disconnected both to test, and the sound still persists.
Car has 150k and has just completed a wp/tb, drive belt, and ac belt change a month ago. Engine is mostly stock with the exception of DC headers that I installed last week (I had this noise before the header install).
Any ideas what this can be?
Old 09-14-2010, 10:11 AM
vtaker's Avatar
Default Re: '94 GS-R - high pitch noise from engine
make a video if you can. it could be almost anything.
Old 09-14-2010, 12:07 PM
jdmlove2006's Avatar
air leak..? jet engine warming up..? lol most likely nothing I hear new noises every other week in all the cars i drive
Old 09-14-2010, 12:45 PM
dudesitsjdm's Avatar
Do you only hear the blowing noise while driving?If so roll up your window.
Old 09-14-2010, 02:15 PM
taiwandiao's Avatar
Will do.
That's what I'm guessing as well, it comes on and off intermediately so I really can pin point what the cause is. It's just really high pitched and comes and goes, thought someone might have a guess to what it is.
That or turn up my radio?
Old 09-15-2010, 08:47 AM
taiwandiao's Avatar
Heard the noise again while parked, sounds more like an air leak than anything else. Aside from my intake, are there other areas of the engine I should check?
I did notice the sound to be more pronounced right when I turn on the A/C system, but goes away in about 2 seconds or so.
Old 09-15-2010, 11:30 AM
Teggers's Avatar
If you have an aftermarket intake, a whistle at certain rpms is typical.
I have a similar noise, and although I haven't confirmed the source, I suspect it's the alternator bearings going bad because it's coming from that area of the engine.
Old 09-15-2010, 12:40 PM
taiwandiao's Avatar
Stock intake. The noise is more noticeable during idle.
OSIRIuS23
01-18-2013 05:26 AM
mahapowerpgx
11-29-2011 02:12 AM
94hondaon16's
08-11-2008 03:16 AM
Ibuprofen
01-10-2002 03:51 AM
Quick Reply: '94 GS-R - high pitch noise from engine
