GSR running rich, spark plugs white (too hot). Discussion wanted
Old 07-03-2011, 05:22 PM
BoldFart16's Avatar
Default GSR running rich, spark plugs white (too hot). Discussion wanted
I can tell my GSR is running rich (horrid gas mileage, not to mention my A/F gauge telling me so) yet my spark plugs indicate they've been getting too hot (indicating a possible too lean fuel mixture). I could probably use a tune I know, but before I do I want to fix what I can. Chime in with your two cents, it usually helps.
Old 07-03-2011, 05:27 PM
dk=gsr's Avatar
Default Re: GSR running rich, spark plugs white (too hot). Discussion wanted
what ecu you using?
Old 07-03-2011, 05:38 PM
BoldFart16's Avatar
Not completely sure on that, to be honest. I know it's OBD-1 p72 or P13 (which would be the simplest explanation for it running rich) because the IAB is working. All the serial numbers were removed possibly by the previous owner.
Old 07-03-2011, 06:16 PM
beastinisgr8's Avatar
Mine runs rich do to a leaking intake manifold gasket.
Old 07-03-2011, 06:38 PM
Spawne32's Avatar
you have a cheap AFR gauge if you cant tell if your rich or lean
Old 07-03-2011, 06:53 PM
BoldFart16's Avatar
Que? My first post states that my gauge indicates a rich fuel mixture. Even without it I would have been able to tell I was running rich. It's the spark plugs that throw me off a little.
Maybe I should have asked for only two cents that are indicative to a solution...telling me my gauge is cheap based on your inability to read properly is not needed or welcomed
Old 07-03-2011, 06:58 PM
Spawne32's Avatar
so what is your AFR if your running rich but show signs of lean, you didnt post any numbers
Old 07-03-2011, 07:01 PM
racebum's Avatar
post is worthless so far
what engine as has it been modded? a stock b18c1 will use a p72 ecu period. if it's changed so might the ecu be
change the fuel filter and make sure you have 40+psi at WOT
use a ngk heat range 6 plug and drive
Old 07-03-2011, 07:17 PM
BoldFart16's Avatar
Stock B18C (JDM) I/H/E
Intake manifold is a brand named "HAD", which is hard to look up, so it may not even have IAB.
ECU has only "94 Civic" written in marker on it, so I'm assuming p28 ECU. Has chipped switched to "OFF"
I have a fuel pressure gauge, indicates 40+
Using Iridium IX heat range 6
AFR is 11.1-11.5 at idle.
Old 07-03-2011, 07:28 PM
Spawne32's Avatar
so your super rich at idle, and how about WOT? sounds like your just poorly tuned
Old 07-03-2011, 07:33 PM
racebum's Avatar
bingo, wrong ecu, get a p72 or, since that ecu you have is obd1, chip it for crome and run a p72 basemap. look at the sticker on the side of the ecu, it should be p28 something or another
even with slightly different manifolds a gsr on a p72 will run fairly well. the p28 is just designed for another engine which has a completely different map signal due to different cams and less displacement
Old 07-03-2011, 07:37 PM
BoldFart16's Avatar
It gets leaner (13.9-14.7, 14.7 being a little too lean IMO)
I agree, I could definitely use a tune. I would just like to get the proper ECU before I go to my tuner. I really need to figure out the brand of intake manifold I have. If it doesn't have IAB then my unknown chipped ECU will probably do. If not I need a p72, or new intake mani. Ever seen or heard of "HAD"?
Old 07-03-2011, 08:10 PM
BoldFart16's Avatar
edit
Old 07-03-2011, 08:16 PM
BoldFart16's Avatar
A p28 with a GSR basemap w/o IAB will work better than a p72 with a GSR basemap. You're technically right though since my ECU basemap is switched to "OFF" so it's most likely running a stock p28 basemap. If my intake mani doesn't have IAB I just need to burn a better basemap into my p28, save me some $$$.
Old 07-03-2011, 08:28 PM
racebum's Avatar
that "had" is the throttle body and is oem.
there's no real technical about it. a p72 map must control the engine. it doesn't matter how you do it, just make sure that program is burned on your ecu
now if you still have the gsr intake manifold you have to use an ecu that controls the iab's and that's only the p72. and or you could switch to a blox, skunk or performer x and use your p28 with a p72 map
Old 07-03-2011, 08:33 PM
BoldFart16's Avatar
All I meant was my ECU doesn't need to be changed if my intake mani isn't stock. I do need a p72 basemap regardless.
Lol @ me. That totally was the throttle body. The intake mani is definitely not a stock one though, and could be a no name replica. Nobody makes an aftermarket intake mani with IAB, right?
Old 07-03-2011, 08:52 PM
racebum's Avatar
correct, post a pic of your im and i can probably tell you what it is.
in short, if you have a blox manifold or something of the sort, sure a p28 ecu will work provided you put the correct map on it with something like crome
Old 07-03-2011, 09:11 PM
BoldFart16's Avatar
Will do, give me a sec.
Old 07-03-2011, 09:18 PM
BoldFart16's Avatar
Old 07-03-2011, 10:23 PM
racebum's Avatar
blox, old skunk, some sort of itr copy. a p72 map on your p28 will be absolutely fine. you can actually milk a bit more midrange with an actual tune since the timing can be bumped up in the 3000-5000rpm band with a single runner. probably not worth the cost but you might be able to find a single runner gsr map if you ask around. burn that onto your p28 and your car should run like a dream
by the way, why is the vacuum line not running to the fuel pressure regulator? see that vacuum port on the upper right of the manifold, that should go to the fuel pressure reg
Old 07-04-2011, 12:17 AM
BoldFart16's Avatar
When I installed the AEM fuel pressure regulator I didn't have that line so I looked up if I could run without it and turned out I could, so I left it be. Fuel pressure is higher, but I don't know if it affects performance.
Old 07-04-2011, 06:31 AM
cdaiscool's Avatar
Running without a cap on that is akin to driving with a vacuum leak, as it is a vacuum leak.
Do you normally have it plugged at all?
Old 07-04-2011, 09:10 AM
BoldFart16's Avatar
It has a cap on it. The yellow in the picture is a rubber cap. The vacuum line on the back side (out of sight in the photo) is also capped.
Old 07-04-2011, 10:40 AM
racebum's Avatar
maps are not designed this way, oem ones aren't fuel pressure changes with vacuum. get rid of the regulator and install your oem fpr, hook up the line and run a p72 map.
really simple
Old 07-04-2011, 11:51 AM
BoldFart16's Avatar
really simple
Well since I need a tune even if I do all that, why not just have the tuner give me a custom map for my vacuum line-less fpr? That seems to be the simplest and least expensive thing to do.
Art Vandeleigh
03-29-2005 10:34 PM
TurblowR
12-05-2004 02:26 PM
Uman
05-16-2003 11:55 AM
J337_UNIT
04-13-2003 04:29 PM
Quick Reply: GSR running rich, spark plugs white (too hot). Discussion wanted
