94-01 Rear main seal install help?
I have a 99 LS integra that I am changing the rear main seal on. I am using the felpro gasket set and it came with the seal and 3 wrong gasket for the outer edge of the casing that bolts to the engine. I realized the gasket set was for a few different models which is why there are 3 extra pieces. Anyway my big question is what do I need to seal the outer casing with when I bolt it back to the engine? Im guessing RTV is a no no. Im also considering on going to Acura to get an Acura main seal to be safe.
Re: 94-01 Rear main seal install help?
i got my rear main seal from acura cause i used 2 cheapo autozone ones and they kept leaking, some people just pry the old one out and stick on the new one but i just pulled the whole housing out, hondabond or rtv seal it then stuck the rear main seal on, goodluck on your journey
blitzinq
10-02-2016 11:08 AM
EF'GSRrr91
09-01-2014 06:15 PM
drsab2000
11-03-2012 08:05 PM
