91 integra starting problems
So I swappaed out my trans and put a new clutch in. But now that car will not start. It clicks then nothing. What could this be?
Re: 91 integra starting problems
check your battery connections first. make sure the grounds are connected also. do you hear a lot of clicks or is it just one click?
Yeah it all looks good checked all the grounds and the battery and its all in working order. I'm just stumped on it
what about the ground for the thermostat, i remember i didnt connect that by accident and didnt start when connected again it started
well it has to be a ground wire or your battery or the connection to the starter itself. you might have unplugged it when you took off the tranny. make sure it is plugged in all the way. then check for voltage on it.
Well I got it going but its weird I think the starter was effed up some how because I threw my buddys in and it started right up. Wouldn't do anything with mine.
Thanks for you help everybody
memorybox
01-26-2007 01:26 PM
sparxx
01-06-2004 02:46 AM
