60K tune up on 2000 gsr, hard to do or not?
Got a 2000 gsr, needing a 60K tune up.
Somebody wanna fill me in on what I need to do and if there's any helpful sites I can check out. I'm more concerned about the valve adjustment. I've done the basics on my own, springs, shocks, headers, exhaust, intake, oil change and some other random stuff. Is the valve adustment hard to do?
Any response is greatly appreciated. Thanx for the help anybody can give.
Re: 60K tune up on 2000 gsr, hard to do or not? (Jmonkey327)
http://www.team-integra.net/index.asp
all the info you need should also be in your owner's manual. valve adjustments are hard to do, you'll just need to practice. the first time is a bitch though. the link should help you with a lot of things though
if you've done all that you list above I don't think you will run into any problems doing the 60K maintenance and valve adjustment.. and you probably have most of the tools..
its mostly replacing fluids, valve adjust, valve cover gasket, cap/rotor, fuel filter and checking over a bunch of other things for wear, leaks, etc (brakes, suspension, steering, belts, etc...etc..)
here you might wanna check out these links
http://www.bseries.net/html/garage/valveadjust.php
http://www.c-speedracing.com/howto/v...alveadjust.php
http://www.helminc.com (to buy a manual)
Re: 60K tune up on 2000 gsr, hard to do or not? (GSRaCeRbOI)
Hey, thanx for the info and the link. The link was really helpful. Greatly appreciated.
Teg44
06-19-2001 11:17 AM
